^ what she said
Just went to the local hipster beard place to get some new beard oil.
Apparently, when asked what you need,
"something to make me look a little less homeless"
is not a usual answer :blush:
  • Like 1
Definitely isn't.
Preferably something from the Zztop line of products.
lol
my beard is not worthy of that high standard
I just use the pantiene leave in conditioner I put on the hair in the morning and give it a quick brush. Comes up soft as to alleviate the red coloured steel wool. Helps to repel chromium, magnesium,iron, fibreglass and diesel soot. As well as a deadly combination of the above said fumes.
Gone to parents for mums birthday and driving skyline.
2 cops changed direction and followed me but didn’t stop me.
Must be trying to scare me....it worked
Did you rego it? Brrrrr. Pop,pop, bang. Or just start shifting at 2000rpm. 5th to neutral 200m before the lights. [emoji23][emoji106][emoji61]howdy Ho.
About 280?
281.2? You gotta post the graph cobra. How will we know if it can out run the mercury with moon discs a b&m mega shifter with a 10 speed tranny and loaded shot gun? And icy cold air con.DSC_0197_2.JPGimages (1).jpeg
First one I crawled past in a town at 40. Followed me out of town then passed me only to immediately pull over the car in front of me
2nd was at a roundabout and I couldn’t really keep the noise down but he changed direction to follow me but then turned off
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
