5 hours ago, Beyond Blue R33 said:
On a separate note I thought you might like this kieran, Nihari slow cooked beef curry/meat stew. 2kg 2" thick chuck with bone in. 1 kg of beef bone pieces. 6 hrs on the hob covered. I'm about 3 hrs into it. Got garlic naan and some bassmati rice. Garnishing with green chilli, and some julienne ginger and lime. emoji848.png
Now your a pro, come do mine!!
Above 100 so many whistles
Came up pretty tidy. Just won't start now. F##k. Previous owner was a whizz with electrical knots and loose tape. Will be central locking to immobiliser. Going to bed. :-( DSC_0170.JPG
Feb 16th this friday turn up that boost controller at barbs !!!
Members tuning day 1st one for 2018.
You'll need cams lic which pays for it self if you have shannons insurance 10% off your total ! and then become wascc member first day is free.
I'm going regardless not worth doing it back streets.
Hit 3 pink galah the other week in 3rd gear at full noise.
Could have been worse a gumtree or a child.
So im releasing my energy on a track
Got a mate coming too with his new r32 as well [emoji4]https://www.wascc.com.au/events/
Hey dude how did you go out at barbagello? [emoji23]
It was really fun :D car was a pig untill tyres warmed up then she was spastic.
Got a bit worried about my water temp on PFC 103 was the max so im not sure ?
But i was happy :) overall had a photographer come out aswell his 1st car shoot so was a challenge for him but he had the gear i must say had a big $ white lens $
looks like my back yard about 3 minutes after I got my first dirt bike in 15 years [emoji3]
Spinning out stumps one tyre at at time. Re-alignined the windows. Re-wired the central locking back to the immobiliser. Tidy as.[emoji41]DSC_0170.JPGDSC_0174.JPG
  • Like 2
    • You now say stumble, but you said cut out before. Will it slow rev through the cut/stumble? What gap were your spark plugs set to when you them in?
    • I had double clamped all the pipes but I checked them over any way, everything tight and secure. feels and sounds like a electrical short/failure, as it is an abrupt and aggressive stumble, that instantly comes and goes right at 4k mark...like clock work fuel pump and filter are new new coils and plugs injectors where cleaned and tested 200 miles plus ago no black smoke cleaned MAF   same results, other ideas? some other sensor?
    • Yes, just without the annoying use of the word hybrid. We stopped using that term 20 years ago when we realised it meant different things to different people. Even "highflow" can represent more than one way of achieving the goal of getting more flow out of a turbo. But at least it says what it does on the box.
    • OH, when they say "solid buckets", I always interpeted that as "shimless". (Which is not the same as the "shimness word I invented above to represent the same idea that the buckets act as shims also!!). Still the same problem though. So it appears that buying a "kit" from Tomei is a two step process. Makes sense. Doesn't make sense in the context of a "kit" though.
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
