2 hours ago, t_revz said:
Ok who has factory springs for a 33/34 kicking around?
I have them...but my car is currently using them.
Also, i'll probably be making an appearance at Cars and Kebabs tomorrow night at the JB Cannington Carpark (same as last time) Anyone else going?
  • Like 1
Get the price u wanted ?
Paint job looked mint tho!
What now r35 sky33 or the darkside 32
Sold for advertised price, he’s gonna bring a bank cheque Thursday.
It’s all about the 4x4 and camping for now.
  • Like 1
Woke up Friday with a horrendous cold/flu thing. Took the skyline for a spin this morning. No whistles from the window realignment yeay, hopefully no water leaks. ice cold beers are currently massaging the body and throat into a state of submission(b) so I won't be attending. [emoji42]
Yep that's how it goes. [emoji70]. When you get as old as me you'll sell the 4wd get another skyline then when your under the bonnet and dash with it up on stands in the garage you'll wonder why the f**k did I do this? Glory days. Been dreaming through the just cars MAG. Wouldn't mind a impala, Chevell or camaro/mustang. [emoji848]
Just spent the day stripping the parts bike, and if you ever get sick of swinging spanners on a car, try a bike. Fkn things are SO much easier and less pressure on the body - which counts when you are an old crip like me :blush:
  • Like 1
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
