2 hours ago, t_revz said:
Ok who has factory springs for a 33/34 kicking around?
I have them...but my car is currently using them.
Also, i'll probably be making an appearance at Cars and Kebabs tomorrow night at the JB Cannington Carpark (same as last time) Anyone else going?
  • Like 1
Get the price u wanted ?
Paint job looked mint tho!
What now r35 sky33 or the darkside 32
Sold for advertised price, he’s gonna bring a bank cheque Thursday.
It’s all about the 4x4 and camping for now.
  • Like 1
Woke up Friday with a horrendous cold/flu thing. Took the skyline for a spin this morning. No whistles from the window realignment yeay, hopefully no water leaks. ice cold beers are currently massaging the body and throat into a state of submission(b) so I won't be attending. [emoji42]
Yep that's how it goes. [emoji70]. When you get as old as me you'll sell the 4wd get another skyline then when your under the bonnet and dash with it up on stands in the garage you'll wonder why the f**k did I do this? Glory days. Been dreaming through the just cars MAG. Wouldn't mind a impala, Chevell or camaro/mustang. [emoji848]
Just spent the day stripping the parts bike, and if you ever get sick of swinging spanners on a car, try a bike. Fkn things are SO much easier and less pressure on the body - which counts when you are an old crip like me :blush:
  • Like 1
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
