worst thing about working in the CBD - lunchtime crowds
best thing about working in the CBD - crop dusting alfresco dining areas with a fart so greasy and putrid it made ME gag
its been a slow day
  • Like 1
Crop dusting is great.
Should be more of it
When the wife is taking too long at shopping in the clothes section. Drop it dust it move away and give her funny looks along with the other women till she realises my evil plan. [emoji43]
  • Like 1
its been a slow day
Smells great let's try this place. Reconstituted ribs, Tripple cooked chips with miso lubrication. [emoji372] how's the new job going dale?
the new job is pretty fkn awesome actually. Someone finally came up with a laptop that will handle a decent 3D model, and we all got one, so as of May we will be allowed to work from home, which is nice.
Anyone else checking out this weekends BBQ comp? I will be down there eyeballing the proceedings, as I am thinking about taking these guys on in the next one. I even have a couple of chef ring-ins lined up for my team
4 minutes ago, t_revz said:
Anyone ever been to Olympics/commonwealth games etc?
The ultimate exploitation of the proletariat by the bourgeois?
Nyet, comrade
Nyet, comrade
Have been planning to go to 2020 in Tokyo but I underestimated cost per event. No point going just to watch 1 or 2 events. Considering going to japan next year for holiday instead.
12 minutes ago, t_revz said:
The proles will be fine.
They don’t know any different
:rofl:
its funny because its true!!!
I went to Beijing 2 years after the Olympics, if that helps
I went to a opening night party omce if that counts? A shot for every country announced.... got mess quite quickly lol
10 hours ago, TiTAN said:
More surprised the whole party didn't end up in the hospital with alcohol poisoning with those rules.
Most people gave up or passed out. Was along time ago when we were young and stupid lol
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
