On 02/05/2018 at 10:51 AM, ElleAli76 said:
Hello boys ! Back in Perth yesterday , Saudi was good , just a bit hot from my liking emoji28.png anyway need help - anyone knows any contact or trust shipping company in Melbourne ?
Welcome bk!
  • Like 1
29 minutes ago, t_revz said:
Boo
Ghey
I know, right?
on the upside, dude fitting the tyres complimented me on the complete lack of chicken strips on the old rear knobbly.
REALLY need to find a bloke that does epic fabrication on fuel tanks too, if anyone has any suggestions.
Hi,
Wheels arrived from Japan. 18x9.5 +15 old skool
The SSR Type C were released in a gunmetal colour (and a bronze and gold). really wanted the colour code....
Contacted SSR via emails and facebook message to their 3 sites. most wont reply. and one in Aus says they wont give out the information.
Might just have to go some custom gunmetal. . . Bagh frustrating.
ranged from $100 to $300 aud per wheel for the work =/
Good reviews on google of "alliance rim repair".
  • Like 1
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
