And that's why we all love Hank!!
I take it the shopping spree means the offset is going well?
I am looking at Kamodo's at the moment. Too much weber love to go for an offset, but there is always room for expanding the fleet, amiright?
even I cant justify spending that much coin on a bbq, or the big green egg would be a dead cert!
In other news, John Harvey Kellog, the guy famous for inventing breakfast cereal, also invented the health sanatarium, the electric blanket...
...and a machine that could fire 15 GALLONS a minute of water up your backside, and if you were unlucky enough to undergo this treatment, you could look forward to it finishing up with a half gallon of yoghurt going straight up the newly cleaned colon....
lulz
The new bloke from Tasmania who started here last week called the boss this morning to tell him he was sick and couldn't come to work.
The boss told him "Mate, we are flat out here, and really need your input on this quote. How sick are you?"
Tasmanian mate replies - "Well, I am in bed with my sister..."
That reminds me - we need to plan another playdate for our boofheads. We have a brand spanking new dog park just behind us now, with 3 separate fenced off leash areas.
Every time I take HRH Princess Blossom Pops down there, everyone else bails to one of the other areas and we end up by ourselves - its fkn awesome
For sure!
What is it about 2, large, black individuals that make people run away? :P
  • Like 1
    • On the hot side pipe work, or if you want to compensate for pressure loss from the IC, post intercooler on the cold side, pre-throttle
    • They're notoriously difficult if you traverse forums... the 102TB and FAST102 are so bad that most people actively don't buy it unless they REALLY want that extra 1hp. The idle stuff isn't really that hard. The cam is pretty manageable and while it acts like a larger cam the whole car actually drives smoother than before. I like to just tinker so if I can get 50rpm less variance or rule out situations where it does 'unexpected' things it's fun for me. HOWEVER If you just let a tuner give it a guess for a couple of hours and had no way/desire to test and tweak it yourself you'd spend a lot of money at the tuner or be pretty frustrated, that's for sure. But yeah. Drives great. (then I drive partner's Civic Type R and I think.. well, more tweaking to do) But for what it is (cam, TB, intake, manual etc) it does commute around really great once you figure out how the idle tables and GM's systems intend to work.
    • I usually source pressure on inlet manifold after throttle body
    • Where is the best location for boost pressure source when running mac 3port boost solenoid?  my new turbo does not have a fitting for that on the compressor housing.  how come Garrett make a turbo without that?  im confused
    • From my memory, which isn't that great, we did have issues getting the large throttle body on my old LS1 to play nicely at idle, first it would stall, then it would only idle at 2k rpm, then it would hang at 2k rpm for a few seconds and then drop and stall, then, finally, the best we got was it would hang at 1.5k rpm for a few seconds then drop to around 800 rpm The tuner stated that large cable throttle bodies are a PITA, and if I wanted anything better than what we ended up with I would need a electronic throttle body and all of the aftermarket ECU stuff to run it
