how goes the newly minted loinspawn? Getting much sleep?
My youngest came over to  dinner to display her first tattoo last night.
I actually quite liked it :P
Aaaand same as last holiday up north..... car breaks down near Carnarvon on the way home... thinking MAF or TPS. Idled 50km back to caravan park from gorges. Now to study up so I can test stuff in the morning. Nearest town 175km
Fark dude.
I know a pretty good auto sparky......
38 minutes ago, turboedsloth said:
I can not confirm nor deny that i have tested it
In the words of the great sage of our time, Kevin Bloody Wilson
"...if you say you don't, your a liar, and a fool if you say that you do...."
waaay sweeter than you expected, amiright?
  • Like 1
Happy Friday all!
My mechanic in Texas doesn't reply to my emails with "No worries" or "sounds good", oh no. He replies with "10 4" and it makes me smile every damn time.
  • Like 1
Ah fk.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
