23 hours ago, Hank Scorpio said:
Ordered a box of jamwood and a box of cherry from your mates at Flavourwood last night.
Going to be a big weekend of dessert, as the mrs has an order from the blokes at my work for a massive cake, and I will be doing my dessert entry.
My back patio is going to smell amazeballs
  • Like 1
Yeah I used to make it.
First tip - don't trust any yeast that comes in a package with wort etc. Every time I did, I would get bugger all fizz in the bottle. Swapped it out for a behind the counter yeast from my local brew store and before I knew it, I had bottles exploding regularly :D
Also - if you end up with an alcohol content above 10%, its best NOT to mix it with dark rum, no matter how much of a good idea it sounds...
Lastly - buy a bottle washer. Trust me on this
Sounds awesome! *drools*
What could possibly go wrong?
niiiiiiiiiiiiiiice
Well, 12 hours into my first ever 24 hour sous vide adventure, and the meat looks exactly the same  O_O
so if I kill myself with food poisoning tonight, I want it on public record that the dog gets my playstation 4
1 hour ago, Stinky Rooster said:
niiiiiiiiiiiiiiice
You'll be fine.
Are you reverse searing or?
4 hours ago, Stinky Rooster said:
That's the plan, but I will probably just use a skillet, as firing up the kettle for a 3-5 minute love in with Maillard seems like overkill
I'd do the former for sure.
holy shit they were amazing. The Good Wife put together a reduction from the bag juices and we smashed them so fast I forgot to take a pic :(
They held together in the skillet really well, but soooooooooo fkn tender and juicy
sous vide is officially win
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
