23 hours ago, Hank Scorpio said:
Ordered a box of jamwood and a box of cherry from your mates at Flavourwood last night.
Going to be a big weekend of dessert, as the mrs has an order from the blokes at my work for a massive cake, and I will be doing my dessert entry.
My back patio is going to smell amazeballs
  • Like 1
Yeah I used to make it.
First tip - don't trust any yeast that comes in a package with wort etc. Every time I did, I would get bugger all fizz in the bottle. Swapped it out for a behind the counter yeast from my local brew store and before I knew it, I had bottles exploding regularly :D
Also - if you end up with an alcohol content above 10%, its best NOT to mix it with dark rum, no matter how much of a good idea it sounds...
Lastly - buy a bottle washer. Trust me on this
Sounds awesome! *drools*
What could possibly go wrong?
niiiiiiiiiiiiiiice
Well, 12 hours into my first ever 24 hour sous vide adventure, and the meat looks exactly the same  O_O
so if I kill myself with food poisoning tonight, I want it on public record that the dog gets my playstation 4
1 hour ago, Stinky Rooster said:
niiiiiiiiiiiiiiice
You'll be fine.
Are you reverse searing or?
4 hours ago, Stinky Rooster said:
That's the plan, but I will probably just use a skillet, as firing up the kettle for a 3-5 minute love in with Maillard seems like overkill
I'd do the former for sure.
holy shit they were amazing. The Good Wife put together a reduction from the bag juices and we smashed them so fast I forgot to take a pic :(
They held together in the skillet really well, but soooooooooo fkn tender and juicy
sous vide is officially win
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
