lolz
The idea is almost as funny as the one about you country bumpkins still having a milkman.
But personally, the thought of having more than one person in the house intentionally shitting their pants on a daily basis is enough to make me take a 3-4 year break between loinspawn
lolz
Once they start on solids you pretend you can smell it until the phone rings or knock on the door, then ask if the other half can check while your busy :)
8 hours ago, Stinky Rooster said:
holy shit they were amazing. The Good Wife put together a reduction from the bag juices and we smashed them so fast I forgot to take a pic :(
They held together in the skillet really well, but soooooooooo fkn tender and juicy
sous vide is officially win
I've gotta get me one!
My rib eye turned out mint, barely fit on my plate, couldn't finish it, Hank was happy.
Jade is doing this to me at the moment when she comes over to the shop
aldi brah.
cheap, nasty, and works way better than you have any right to expect.
Also, I am SO looking forward to having my dawg surrounded by long noses this weekend.
It will be like walking a fat german tourist through Dachau
there is so much win here, I cant even.
22 minutes ago, Stinky Rooster said:
aldi brah.
Haha! Hopefully there will be a really big grey or 2 in attendance for you. Also hope Hank gives Xena his calming abilities :P
I just posted on the walk's FB page checking it was cool for me to invite an outsider, don't wanna' be that guy who pisses everyone off! haha
no doubt he will. The mrs almost didn't believe me when I told her how casually you had her eating from your hand on the weekend.
I don't know if you noticed, but even the girls at the dog café couldn't get her to take any treats from them.
I did notice that.
However here is my take on the situation -
1) She's met me multiple times
2) I'm Adorable
3) It was at "Hank's House" and I think she felt comfortable with all the Hank smells
4) There were multiple other dogs at the cafe
What a good doggo.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
