sounds like a good time was had by all!!
Hope the slice and dice session with the vet isnt for anything srs.
If they have any left over bits, hook a brother up?
Hanky can smoke the remaining anus components imagine a gently smoked ring as your dessert!
When Martin said you kunce were discussing smoking with Dale, I came in hard and fast ready to talk about pot...
I certainly mis-judged that one.
I did want to leave it up to your imagination [emoji23]
Im not sure how to take that..... ?
Well doc says I have guts
Everything where it belongs. Now just wait for biopsies. Still potential to have coeliac disease
That’s not good my aunt has it she’s skinny as a rake a few issues with gluten dairy etc
Admit it
You really thought about pole smoking first
  • Like 1
I was ready to be inundated with facts and the political reasons that a plant was out-lawed. That's how you should take that.
Facts?
This is the wasteland! Leave your facts at the door!
Kthanx
Yeah I worked with a bloke who had that. Man he used to get massive gut aches. Took the doctors ages to diagnose it.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
