On 1/26/2019 at 9:06 AM, t_revz said:
Happy invasion day bishes.
Hope it warms up to help the beers go down
In honor of our indigenous folk, I spent invasion day listening to the blues
Your welcome, unna.
  • Like 1
1 hour ago, Hank Scorpio said:
Dude, those pork ribs we had were next level.
We need to do a massive cook up in the cooler months. Brisket, beef and pork ribs, sausages.
I am down like an extra chromosome. A WT feed like days of yore sounds like an epic idea
and yer, best ribs I have ever sourced. Sooooo meaty!!!
Melville Heights Meat for those of you playing at home. The main man Ian is a god of all things meat, and if you are looking to source restaurant quality cuts to impress someone, you cant do much better.
In other news, my first attempt at a sourdough came out way better than I expected.I kinda screwed the pooch at the end getting the final shaping right, but taste, texture and proving my starter was right came out spot on.
The perfect wasteland accommodation on your next trip to Belgium.
http://verbekefoundation.com/en/slapen/casanus/
Cas Anus. Only 120 euro a night.
  • Like 1
  • Haha 1
Equipped with lightening
Does that mean it makes you skinny? Or you can strike ppl down with 1.21 jiggawatts?
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
