f**king shit dream boats, Should be able to get it off easily. FYI you will need to acquire a permit for the intercooler as a modification been done to the car.
There's a form online some where if i get a chance to look today I will send you a link.
Wtf first I have heard of it, Mark didn't mention that just said to put mesh on it
Just now, Shoey84 said:
But it also depends on where you take it too and if there nice about it.
I went to the place in Welshpool, was polite to the guy, we talked about the cars when they were new etc...he even licensed it with the turbo timer on.
  • Like 1
1.2 MODIFICATIONS REQUIRING CERTIFICATION UNDER LA CODES The following is a summary of modifications that may be performed under Section LA:  Fitting engines greater than 120% of original power and/or engine mass;  Fitting performance engines;  Fitting engines from non original equipment sources;  Installing a supercharger or turbocharger; and  Modifying the engine and engine components that results in an increase in engine power of more than 20% and/or affects exhaust emissions.
https://infrastructure.gov.au/roads/vehicle_regulation/bulletin/pdf/NCOP3_Section_LA_Engine_01jan2011_v3.pdf
My thoughts are if you have all you paper work taken care of they cant pick on anything.
Also Matrins car is in very good condition just the mods can be picked on if they decide to do a emissions test.
18 hours ago, t_revz said:
doctors orders?
Nope just my knees starts clicking after I do high impact or if I walk up and down steps too much. Trekking to Everest Base Camp was fun hahaha constantly thinking when my knee is gonna call it quits.
18 hours ago, shoey85 said:
f*cking p1gs stickered the R34 tonight while the wife was on her way home! Didn't like the lights and they think the engine leaks oil WTF!
Gotta hate the bacon, got nothing else better to do.... Bad news here too, something's let go on my car and its using alot of oil and occasionally blows lots of smoke ?
buggar, rebuild time more powah!
  • Like 1
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
