I have Peavey Studio Pro 112 (single cone... Like 1 speaker or whatever you call it) amp and an AXL Amp Rapture Series quad box - http://www.axlguitars.com/aarap100hr412c.html
There are better ones out there but this only cost me $750 with the Head and Quad box. + I run my guitars through a Boss Metal Zone pedal anyway.
nice setup!
do you use any other effects besides the metal zone?
  • Replies 100
nice setup!
Hah!
I would love to own the whole BOSS Pedal series, like how they put it on display in the music stores.
But I would probably only use a few but anyway.
I only use the Metal Zone atm, I was thinking of buying a few more Distortion Pedals... BOSS make a Turbo Distortion Pedal, but I figured the Metal Zone can replicate that and a few other pedals so I have just stuck with that.
The Metal Zone can replicate a Fuzz, Overdrive and various Distortion Pedals + a few more pre-set settings... So it is kinda like a few/multi pedals in one.
Gota friend who's got a V-Amp effects unit and it contains probably over 100+ effects... You can sit there all day playing around with it.
Hah!
yeah i have a korg AX1500G effect processor but only use it for practice and song writing... for gigs, rehersal and recording, i have 2 x distortion pedals - a vox cooltron bulldog and a mxr distortion iii... gives me a bit of variety... i don't use too many effects, i have delay, chorus, compressor, wah... i also have a tuner with mute and a noise supressor... pedal board was a bitch to make! i'm sure if i had the $$$ i'd go nuts and buy heaps of different pedals...
Edited by Evil
I use a POD :P 30 amps in one.
i hear they're pretty good...
although i am not the biggest fan of tone modelling and multi effects... i used to love it but found i could get better tones mucking around with a few pedals...
Well it's a proper amp simulator. I pick an amp (say a nice Mesa Boogie) and then I pick a cab (ranges from small practice amps to huge 4x12s), set the gain and EQ levels, then I go straight into my recording interface.
If I was doing gigs then I would use a real amp. The POD does a very good job though. A lot of qualified audio people haven't been able to tell the difference between my POD and an amp.
How do you find the KORG, VOX and MXR effect pedals as apposed to the BOSS products?
Or are they pretty much the same..?
The KORG AX1500G would be fun to use.
Different sounds and effects can help a lot with song writing as it also brings out a lot of interesting sounds, which you can make into a song.
+1 for Metal Zone
wouldn't mind a nice delay pedal though
+1 for Metal Zone
Digital Delay would be sic for echo effects!
Flanger Pedals are fun.
Any of you tried an Acoustic Simulator? Does it really make an electric guitar sound acoustic?
Nah, not overly. I think it brings out the warmth of an acoustic but nothing can replace the true tones of an acoustic guitar.
Yeah that's for sure, I guess it save you from bring 2 guitars everywhere.
Still the best acoustic sound is from an acoustic guitar.
i love the vox and mxr pedals :P i have some boos pedals...
most of the boss are digital and have buffered bypass whereas the vox and the mxr have true bypass and are analogue... but they are all great... boss dd3 is a fantastic pedal!
the AX1500G is really good for practice (headphone jack means you don't need an amp)... some good effects and poor mans POD type amp modeling...
Whao! :P
That's some awesome equipment there!
"most of the boss are digital and have buffered bypass whereas the vox and the mxr have true bypass and are analogue" - How do you mean digital and true bypass?
Does that effect the sound of what the pedal will produce through your amp?
Whao! :sick:
buffered bypass is a circuit within guitar pedals that attempt to remove tone suck when the pedal is switched off. this is done because if you have lots of pedals in a chain, the signal can get weaker and the sound can be tanrished.
in true bypass, when the pedal is off, it's like its not even there.
as for digital and analogue, digital pedals can sound a little artificial, not all of them boss make excellent digital pedals (DD-3 being a prime example).
Good example of this is can be shown just by plugging a cheap effects pedal in without it switched on...the sound is noticeably different to plugging your guitar straight into the amp. Even on a 10 watt practice amp :sick:
Right I see...
Thanks for that!
Good example of this is can be shown just by plugging a cheap effects pedal in without it switched on...the sound is noticeably different to plugging your guitar straight into the amp. Even on a 10 watt practice amp :)
100% correct! tone sap is a big issue. so is level reduction...
Right I see...
Thanks for that!
no worries! i learnt a lot of stuff talking to other musos... i am still learning stuff...
Ok one more time... Haha!!
Most BOSS Pedals have a buffered bypass to reduce the tone suck, hence not tarnishing the sound = Still keeping a very Clean Channel sound when the pedals are off.
Ok got ya!
Cool! :)
Don't need one :)
Benefits of having a strat copy with a 5-way pickup selector and no humbuckers! On the 2nd and 4th positions most people can't tell my guitar from a recorded accoustic!
I reckon all the guitarists on here should have a solo/riff competition, where you record 15 seconds of sound and post it up. Don't know how judging would work though :S
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
