raced the BMW 320 Turbo today in Project Cars, man such a fun car. crank up the boost to 2.6 bar and let it loose. got the ol' skool no-power-till-6grand kind of turbo.
(turn up the quality)
love a bit of dirty overtaking ;)
They are redesigned and modified specifically to suit a particular Sim and are easily added as long as you understand the directory structure and follow the Info Text file.
I can get on TS if you like to give you a hand with rFactor, GSC, Assetto still learning what makes PC tick .
  • 4 weeks later...
got lucky, bought a new gaming laptop and reloaded PCars only to learn that the savegame does not travel to the steam cloudstore.
luckily for me i removed my old ssd cdrive and could recover the folder. there was no way i was doing the damn 24hour again.
Built with a budget but I suspect you might struggle with higher end Racing simulations such as Assetto Corsa and Project Cars unfortunately.
What Graphics Card ?? I know that there is on board graphics but that is for the Office for good gaming experience you have no choice but to invest in a good PCIe Graphics card.
Some AMD Chips run pretty hot and for the cost of it I'd have gone to something like a Corsair H80 or H100 Liquid Cooling, draw cool Air into the case near the floor and channel this through the case to ventilate it and remove as much heat as possible by air flow, IMHO there is no substitute for Airflow
The HDD you have selected is adequate for your needs but a relatively slow one at that even though it is SATA 3, and your only using one HDD ???
IMHO you should be using no less than 3 HDD's or more for general programs etc and an SSD for the OS .
Basic layout might be something like that listed below
1 OS should be on a 60Gb/120Gb SSD and ONLY the OS
This requires installing the OS and then editing the registry externally in Safe Mode so the default location of your User folder and the default location for your Program Files is on other drive's and NOT C:\ .
2 All other programs are installed something as follows
D;\ For your User Folder and Documents
E;\ For general Programs and Applications
F:\ Being a 500Gb 10,000 rpm Gaming drive so you have some decent speed of I/O .
G:\ Being a 500Gb 10,000 rpm Gaming drive so you have some decent speed of I/O.
H:\ A Caddy for removable Large HDD used for creating Images or Backup's of you installations.
( The reason behind divorcing the OS from everything else is 1 it is faster and 2 it greatly protects your installed programs from loss of data should your OS fail and eventually it will.
So if you back up your C:\ ie your OS regularly to an internal caddy removable backup drive the heart of your system can be protected with minimal loss of Data )
HDD Caddy fitted to the system and you insert a backup drive and image your C:\ and D:\
Storage and backup space is cheap,
What OS ? 32 or 64 Bit you didn't say and IMHO I'd not install Windows 8 for gaming. it is NOT flexible enough to allow custom installations and designed primarily as a Multimedia platform.
Cheers for reply yea was more a budget work computer just wanted to know if it would run games.
Yes the ssd was for OS, no graphics card atm but if the rest isn't good enough I won't even bother and just at a later date upgrade it or build another I guess. But sounds like almost everything must be changed for it
Not necessarily , but that's how I build my systems , and why I separate the OS from everything else and make images of the OS ,
That system would likely run OK for rFactor and Game stock car but I think you would need a high end graphics card for serious gaming simply due to the complexity of the graphics texturing but more so because the computing power is done by a GPU Graphics Processor Unit freeing up a LOT of CPU cycle time to run the mathematical calculations needed.
Suck it and see would be my advice as many games have a trial, to test your machine's capability.
The BAC mono is another fun car to drive, can hold some good power slides.
Edited by HR31_RB20DET
which sim has the biggest list of aussie tracks? Prefer scanned tracks but mods will do also.
It would be hard to beat rfactor for sheer number. If you can get past the ageing graphics its still one of the best sims, especially with the realfeel FFB plugin.
Exactly. I listed 20 aussie tracks off the top of my head - I'm sure there are more that I forgot about. Ageing graphics don't bother me. I can see where I'm going, can use the car's gauges to give me vital info, personally I don't need any more bling than that (and my Dell laptop won't run anything much more graphics intensive than that anyway)
Realfeel is good, but takes a bit of setting up to get it feeling right
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
