Hey guys,
I know this has been said to death about how to setup timing and all that, searched around and found a lot of info, but nothing definitive to this question i have.
Doing a 100k service, timing belt etc on my RB25 NEO. Upon taking the covers off and winding the engine over clockwise many times and double, triple and quadruple checking the timing marks, it would seem the exhaust cam gear is out by 1 tooth in the clockwise direction (i think advanced?).
I haven't taken the belt off or anything as yet, trying to make sure I get it all spot on when putting back together.
Is this a trick that some tuner has done for more power? The car has some odd daughter board in the ECU and was "tuned" by Dr Drift. Could they have done this to improve something? Should i put it back the same way?
Thanks, Kurt.
https://www.sau.com.au/forums/topic/456822-rb25-neo-exhaust-cam-gear-question/
Here are some close up images with the stock belt still on. Haven't removed tensioner at all, this is how it was when I took the timing cover off.
Surely this isn't the right thing to have done, every thread i read suggests that 1 tooth is far to much to be of use and actually will kill engine power.
Inlet and Crank line up perfectly.
I suggest - buy ebay adjustable cam gear, the type with the steel outer gear not aluminium, install on exhaust cam. Adjust to stock position, see if it runs better or worser. Move back to 1 degree out if needed, or tune further to get max power. Problem solved for $80-90 and tuneability of engine increased.
One tooth on a cam wheel equates to 15 degrees on the crank.
Usual IGN static timing is 15 degree BTDC and has the CAS sitting pretty central in the slots.
Yours looks slightly retarded, perhaps compensating for the advance on the exhaust cam but one would need a timing light on it to be positive.
If the cam wheel had been set up a tooth retarded, there may have been a plan to bring boost on earlier or such, but set up a tooth advanced looks like a mistake to me.
  • Like 1
Yeah it's a real strange one. I have a timing light so that is no problem to check after. I've sourced an adjustable cam gear so i'll pop that in with it set to 0.. install the CAS at the same mark and see what it times at and adjust to 15 degrees if it's out. Would still love to know if it was a mistake or not... as you said, everything points to retarding it for any purpose.. but not advancing.
Unless you're going to degree the cam wheel I wouldn't bother with an adjustable wheel.
There's not much chance the marks on the adjustable wheel are going to be accurate enough to prove the point.
Handy if you decide to play with exhaust valve timing but you've also got the inlet to think about….too much hassle for me.
Well you have a point. We know that the timing should be on the mark, so really, i should just put it back on that marker. Also most people suggest that the NEO doesn't do much outside of the 0 mark anyway, so having the gear would be pointless? Ahh I dunno what to do now haha! I don't think the adjustable gear (Tomei) would give me enough adjustment anyway to go back to "one tooth out" would it?
Well i don't know what to do. The right thing to do is put it at the right marker. It is supposed to be on that really. From what i've read, i cannot see why anyone would want to advance the exhaust on a NEO by that much. Most say they lost significant power when adjusted outside of 0.
Completely stock. This looks like the first major service it's had in a long time. Certainly hasn't had any "engine work" as such. I just hope there hasn't been some drastic adjustments made in the ECU with the daughter board it has. Doubtful though as it seems to be a pretty basic chip anyway.
  • 5 months later...
Hi bro, just seeing how things went and did u need to set it out by 1 tooth again as I'very just changed all mine and yep 1 out so I set it all up correct and now runs like a bitch. Did yours do same thing? Cheers and I will look forward to your reply. Mick.
Hey Mick,
I haven't got around to getting the car finished yet, still waiting on a new CAS and then it should be good to go.
Strange that your having issues. What exactly is yours doing that is bad? The service manual suggests having the gear line up dead on the marks, and so do the opinions here, makes sense really, i don't know why it would ever need to be 1 tooth more and that info is not in the service manuals.
Hi bro, yeah mine was 1 tooth out on the exhaust side and now that I've lined all timing marks and put new belt on its holding back power a he'll of a lot and when I change into second gear it shoots a flame and just wants to die at times. I have a nistune board on the ecu (daughter board) like you. I'm thinking of putting it back to a tooth out again or leave it and see if a shop can fix it on a dyno tune and remap ect. It's doing my head in bad. Hopefully someone can help.. I will let ya know how things pan out. cheers talk soon.
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
