It’s time for me to sell my beloved GTR as I’m getting a deposit together for a house. I’ve spent over $25,000 on parts, you’ll be hard pressed to find a cleaner 33 GTR.
Car was tuned by JEM and made 297kw on BP 98.
Price is 28,000 ONO – Sorry not interested in swaps or trades
Car is located in Canberra
I will be putting photos up over the weekend
Any queries you can contact me on 0 Four 23492200
Specs are as follows, chances are that I've missed things:
Engine – Rebuilt November 2012 – Can provide majority of receipts
Engine block was completely machined (decked, acid dipped and welsh plugs were replaced, crank balanced, bores honed, oil galleries drilled out, x-rayed for cracks ect)
New CP forged pistons with 9:1 compression
I-beam Forged Rods
N1 Oil Pump with Reimax billet oil pump gear
Trust Oil Sump Baffle with extended oil pickup
New Alternator
All seals and gaskets were replaced with OEM items, with the exception of a cosmetic metal head gasket.
All new OEM heater hoses – Over $700 worth of hoses
New Clutch Fan
ATI 1000HP Harmonic Balancer
Greedy 19-Row Oil Cooler with Thermostat and Oil filter relocation kit
New oil pressure sender unit
Head has been serviced, with new OEM camshafts installed
Nismo Engine and Gearbox mounts
New Thermostat
Turbo/Exhaust
Garret 2860-7’s with HKS actuators
X-Force Dump Pipes
HKS Front Pipes and CAT
3.5 Inch Custom Exhaust
Driveline
Gearbox was refreshed with new syncros at Award and Diff in Sydney in February 2015 new 4th gear set installed November 2014, serviced with Redline Lightweight Shockproof
Transfer case was inspected by Award and Diff and serviced with new transfer case fluid. ATESSA actuator piston has been modified to allow faster engagement of the front wheels.
V-spec Electronic Diff was serviced with new fluids
Nismo Coppermix Twin-Plate Clutch
Ignition/CPU
Spitfire Coilpacks
New coilpack harness
Apexi Power FC with Hand controller
Greedy Profec B Electronic boost controller with hi/low boost settings
Tarzan G-Box Installed – Replaces stock G-force sensor. (http://www.speedhunters.com/2012/06/the-gt-r-gets-tarzan-ed/)
Viper Alarm system with immobiliser, tilt sensor, glass break sensor and shock sensor
Fuel
Walbro 240 hiflow fuel pump
Flow tested injectors
Suspension/Handling/Braking
Tien Monoflex Coilovers
Nismo ball joints
New tension Rods and Universal links
Cv Joints replaced
Suspension calibrated by Capital Steering and Suspension in Canberra
Michelin Pilot Sport 3 – Installed 10,000kms Ago
Nagisa Auto strut braces – Attach to front quarter panel
New DBA T3 Rotors and Project Mu Pads with DOT 4.1 brake fluid
Interior
Reinforced driver’s seat – Frame was reinforced with thicker cold-rolled steel. In addition the seat and backrest foam was also replaced.
Nismo Centre Gauges
Genuine Nissan Floor mats
Exterior
Series 3 Xenon Headlights
Nismo Clear Front Indicators
Nismo Clear Side Indicators
OEM Series 3 Front Lip with Brake Ducts
Series 3 Bonnet Lip and N1 Vents
Nismo Wing Caps (Carbon)
Nismo Weathershields
Other things
New Battery
Serviced with Motul Fluids ever 5,000kms
I have spare parts including stock edu and Quest LED Tail-lights
Hey mate, did you have the motor built, who was it built by and what boost pressure are you currently running through it ? Also is it still running the standard fuel system i.e injectors, rail, pressure reg etc ? Is it neat in the body, has it ever had a hit, paint etc ?
Bump - For everyone thats been asking, yes, this car will pass rego. New tires, legal height and even legal window tint.
  • 4 weeks later...
Been watching your car Since you advertised it on Carsales.
Hope you got close to what you were after, one damn nice car.
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
