Hi,
my blitz base is on the manifold intake as replacement for the original dump valve and the port at the back of it to the vacume.
today i noticed the dump valve is sucking air in as if the blitz is sucking air in from the dump valve port
Also i have no base washer would that matter that much ?
base to inlet manifold.
many thanks
Dump valve is sucking air in on idle
Now i know the dump valve is connected from its base to the inlet manifold which provides the positive pressure feedback
You also have a port/ nozzle or whatever you want to call it at top of the dump valve which is connected to the vacum
I think that port sucks the diaphgram in pulling piston up and letting air out when needed
Now the issue is if you hold your hand or even a tissue paper on the venture of the dump valve it is vacumming and sucking air in
Makes sense?
I'm guessing you're not a native English speaker. Perhaps you need a photo with some arrows pointing out the features you are talking about.
For one thing.....dump valve is not a normal term. We will assume you're talking about the BOV, which is still not even the right term on a Skyline, because in truth, what it really is is a compressor bypass valve.
Because it is a compressor bypass valve, it is actually intended to be connected back to the compressor inlet. The vast majority of stupidity associated with Skylines revolves around venting BOVs. Leaving them open to the air requires that do you a few other mods, most of which don;t get done by most people who like venting BOVs. Hence the stupidity.
Anyway.....please do what I said in the first paragraph.
@GTSBoy
Many thanks for the explanation . Yes I am referring to the BOV or in here is it referred to as dump valve .
I have installed the blitz which is a direct replacement for the manufacture bov.
If you look at the pic below.
1. Area highlighted in red is connected to the base of the inlet which is connnected to the inlet manifold pipe . It has no paper washer between the too metals but it doesn't seem to leak .
2.Area highlighted in black is connected to the vacume ( negative pressure) which I think opens the diaphragm and pulls the bov piston up to let the excessive pressure out.
3. the area highlighted in green is where I am getting vacume on, at idle and across rev range until the bov opens and vents the excess of air in which case it then blocks rather than suck air in .
I know with AFM you are not meant to have BOV as it can run rich between gears but I am ok with that rather my issue is why is it sucking air in .
Is the diaphragm gone so the vacume is sucking air in ?
Edited by stranger12
well I did and as you said it only opens on high pressure ( high rpm range).
I want it to come on from 2k .
I did adjust the screw in all the way and still it was sucking air in , maybe it is by design but I guess that messes the air.fuell ratio as you are getting extra air from the inlet port?
I am currently having misfire and trying to find the cause and this being one of it
If you have no gasket for the bov then I can guarantee it will leak boost above 4-5psi. I tested it even after cleaning the surfaces
Stock bovs leak vacuum too but the air that leaks in has been measured by the air flow meter so it doesn't upset anything.
I hate to say it but unless you go mafless on a different ecu then you're 100% better off going back to the stock bov with an oem metal gasket
Edited by Blackkers
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
