I don't think they would since the Z-tune was supposed to be a limited 20th anniversary model (hence why only 20 were built) BUT you can get a Clubman Race Spec built which actually has improved parts over the Z-tune.
http://www.speedhunters.com/2014/09/gtr-for-the-street-and-track-by-nismo/
  • Like 1
https://www.sau.com.au/forums/topic/457350-z-r34-nismo/#findComment-7548024
Yea but the clubman spec probably won't increase in value or be as mystical as the z tune. And it's 50hp mess and missing200cc isn't it
I don't know if you're being a smarta$$ or you just poorly worded your response. I'll be kind and assume the latter, although it sounds like you've succeeded in making other people conclude the former.
Your question was whether Nismo still built Z-tunes and I answered no with the inclusion of what they could build you at this time. I never claimed to say the Clubman was as amazing as the Z-tune, just that it has features that are improved over that car - uprated brakes, dry carbon pieces, etc. that the Z-tune didn't have.
If you know your RBs then you'd know the extra power and displacement would be easy to fix especially if you have the money to order one from Nismo in the first place...but you don't, so I think you need to sound less facetious when you reply to people who are helping you to satisfy your curiosity. You'd think someone who has a business would at least know that much.
  • Like 1
https://www.sau.com.au/forums/topic/457350-z-r34-nismo/#findComment-7548400
#1/19 Z-Tune is for sale at the moment. Since you're not in the market for one, you won't be able to see it.
You alluded to "mystical" and "going up in value"... What are you after exactly because there are other cars on SAU which are doing just that?
Every single person (I see) who has replied on this thread knows what they are and is familiar with them anon.
  • Like 1
https://www.sau.com.au/forums/topic/457350-z-r34-nismo/#findComment-7548428
Sorry if I didn't explain properly but I said in my first post purely out of curiosity.
In no way am I in the market for another car.
And yes I saw number 1 was for sale.
When I said the clubman is 200cc and 50hp shy of the z tune, I see it had upgraded brakes and other parts over the z tune.
And yes I know it's easy to make up that gap, but with a small run car originality is everything in my opinion so wouldn't be something I would do IF I were lucky enough to be able to afford one.
Thanks guys
https://www.sau.com.au/forums/topic/457350-z-r34-nismo/#findComment-7548467
    • Hi everyone, I have purchased my first GTR and I want to do a single turbo conversion to it. I've been doing as much research as i can and there are a few things that I can find and need to know. I need to run a coolant feed, coolant return, oil feed and oil return for my turbo setup. Here's what I know so far: On the hot side of the rb26 there is coolant feed, oil feed and oil return. Coolant return will be going around the front of the engine to where the thermostat is located. I will need to block off the rear oil return port. I will be running a turbosmart boost solenoid so any of the factory boost stuff wont be needed. Now onto what I don't know: 1. What do I do with the coolant / vacuum hardlines that run around the back of the motor?. 2. What do I block off or loop or move or remove?. I will be running the OEM intake manifold. 3. Is there anything in particular I need to buy for the cold side of the rb26?. I already have the intercooler and pipes sorted. If you have any pictures or information it would be appreciated. Thanks....
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
