A lot of you come and go by Hard Kandy on occasion here and there...
And a small number of us (at this stage) are planning to make an appearance this friday night.
So if your gonna be there, let everyone know and make sure ya come say a g'day :)
I know i'll be there with a few regular SAU suspects...
https://www.sau.com.au/forums/topic/45775-friday-night/
Hard Kandy... one of the shittest rave style clubs there ever was... altho i heard its changed and there arent as many muzzas with their shirts off filling their noses with coke and inflating their egos even higher....
*sigh* if only Cage was still around... with the likes of Serotone and Big Will E
https://www.sau.com.au/forums/topic/45775-friday-night/#findComment-931678
Coked up Muzzas aren't the problem, the "floorboards" were...
Try walking around Bubble with standing on some sik cvnt sitting on the floor.
I mean seriously, why pay $15 to come and sit on the floor and grease people off.
I wish Salt was still open so they could go and sit on the floor there :cheers:
Anyway, I am off to Bass Station this friday but would like to tag along to Kandy some time.
I think you have to be a member (or guest) to get in now???
https://www.sau.com.au/forums/topic/45775-friday-night/#findComment-931747
werd!!! cage was much better... :headspin: as long as the elevator ride up didn't freak you out
https://www.sau.com.au/forums/topic/45775-friday-night/#findComment-931768
Nah when Kandy moved they opened the doors to everyone again
I remember going up in the elevator at Rebirth vs Hard Kandy and thought i was going to die it was so packed it was hardly moving
https://www.sau.com.au/forums/topic/45775-friday-night/#findComment-931796
Ok. Here's the deal.
As a regular HK goer, I can clarify the following.
HK was at Billboards in Russell St and became a members only situation after some of the krew from Salt came over and problems were created (no offence to any Salt goers here but this is simply a fact and I'm not taking shots at anyone).
The "full" members thing didn't work all that well and opened up again to the public with a members priority line.
About 2 months ago, HK moved from Billboards to The Royal Melbourne Hotel which is located on Bourke St between King and Spencer Streets.
Things have been getting better over recent weeks with lineups such as 3 weeks ago when Carbon Based played and last week showed a great turnout due to two hard NRG sets by Paul Glazby & Paul Brisk. More than 800 people walked through the doors on Friday night which is a great number for a type of club which appeals to a niche group.
As for the muzzas and other unwanteds, HK has got a lot better over recent times they are no longer welcome. People in there are all there for the same reason and that is to have fun.
If you went to HK some time ago and were disappointed, I ask you to give it another chance and go again. It has really become something great and I love everytime I go. I have not had one bad experience there.
https://www.sau.com.au/forums/topic/45775-friday-night/#findComment-932198
I used to go abou 2 years ago every Friday night, when the place rocked.
Stopped going due to other committments (read was over the whole scene) but I'm keen on going again sometime soon.
Maybe in a few weeks
BASS OUT
https://www.sau.com.au/forums/topic/45775-friday-night/#findComment-933237
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
