I've done a very thorough search and couldn't find anyone that says the exact size for the Oil Pressure Sending Unit.
I was wondering what type of thread i needed and if i can just use an autometer sending unit. Ultimately using a Autometer Oil pressure gauge?
Thank you guys!
https://www.sau.com.au/forums/topic/457972-oil-pressure-sending-unit/
Cool! Thank you guys. I'll give it a shot. Also I've read somewhere else that the 300zx sending unit is pretty much the same as the all the RB motors. so I'll give that a shot as well because i'm in the states and the 300zx parts are stupid easy to find! Another question on the Oil pressure though:
I live in AZ where the summer weather is 110degrees F.
I drove my car in California where the Oil pressure was FINE. but as soon as I came back to AZ (where I actually live) the oil pressure started to drop. Drop meaning almost to 0. then only getting up to maybe 20-30psi driving. Does Crazy hot weather have an effect on that?
Because in California like i said the oil pressure was fine because the weather is significantly cooler there.
I'm running 20w50 (switched today)
from 10w30
I thought since it's too hot here the viscosity is thinning out too much with 10w30 but even with 20w50 it's still dropping...
Is that a ambient heat issue? I'm going to try and replace the sending unit and if that fails too then I'm almost sure that I'm going to need a new oil pump which is going to cost me quite the bit of money because of Labor. (I don't have the time to be doing my own engine work ATM)
Thanks for your input guys!
It is 1/8 bsp. Which is close to 1/8 npt so can work.
Yikes. Not on my car thanks. Thread pitch and included angle are both different!
http://pipeandhose.com/?q=node%2F2
The "force to screw it in" that 89CAL mentions is because the threads are binding. It's close enough to "work" - whatever that means.. but you will have a large amount of force on the 2 threads that are binding and the other threads are sitting there doing nothing. It won't be kind to either thread either.
Spot the engineer huh :P
Hanbear the 300ZX should have a water/oil heat exchanger.. primarily this heats the oil quickly to operating temp ~85C but it also means the oil shouldn't get too much hotter than that unless you're on a racetrack. 20W50 is extremely thick oil, are you using mineral or full synthetic? I only use full synthetic 5W40.
You need to state oil pressure as a function of RPM as well. For example my car gets about 2 bar (30psi) at idle and then 3-4 bar at 3000RPM once fully warmed up (driving for at least 30 minutes). My last car showed less. The standard gauges CAN be unreliable so if you suspect issues it's best to use a good quality aftermarket gauge.
Just to clarify there's no way I would do it or reccomend it.
I added that quickly as I have posted in previous threads on this topic and someone always comes along and says they use npt no worries.
So. To clarify. A 1/8npt male thread will fit into the 1/8 bsp female thread, poorly.
I said i needed to force it in to get it in not that i actually forced it in
I worked out it wasnt 1/8NPT then made a plan to get around this. So now i have the right fitting in the block to a braided line to an oil manifold for my sensors
I'm only using the z32 Oil Sending Unit because it fits the RB series engines.
As far as the Oil pressure goes. In cool weather it operates fine. I think the standard pressure guage is in Bar increments of 2 right? 0 - 4 - 8?
If it is then here's what it's doing:
Cool weather cold start jumps to 4 then warm goes back down to about 2. and driving goes to 4.
The weather here in AZ it would operate fine when i first start the car for the day. Then I'll drive around and the pressure would go down to below the 2 at idle and then would jump to between 2 and 4 so around 3 driving. Sometimes it'll be at 2.
So I thought that since I'm driving in 110-120 degree F weather the oil is just cooking and thinning out. It's still doing this with the 20w50 in there. :(
I'm HOPING that the sending unit and Oil Cooler will get the job done with a new oil pressure gauge. If not then I know it's my pump or gap between the bearings... which will ask for a Engine Pull.... :(
I'm just hoping.... wish me luck Lol
yeah the standard gauge is kg/cm^2 which is almost identical to bar (there is a 2% difference which can be safely ignored).
the standard gauges are known to be quite inaccurate. from "not bad" to "substantially wrong" depending on your luck :)
my R33 used to idle at 2 bar but when the oil was close to changing would sometimes drop to 1 bar (or less) at idle and only 2 bar while driving (~3000RPM). certain brands of oil showed this characteristic more, some less. I suspect the gauge was overly sensitive around the lower end of the scale TBH
never had a problem with the motor though, I drove it like that for over 100,000km :) so I don't think you need to panic about engine pulls just yet. Get an aftermarket gauge on it just for peace of mind though.
ALL oils lose pressure when they warm up - they get less viscous which means less resistance to flow. Synthetic oils are naturally better at maintaining viscocity when hot, that (and their superior lubricating ability) is why we all recommend them.
Well thank you all for your inputs! I replaced the sending unit with a z32 sending unit today. The oil pressure is holding steady and fine. Luckily for me. Haha. So far.... I haven't driven too much on it but I'll see how it goes. So far it seems that the only thing wrong was my sending unit. Haha. Thanks again y'all!!!
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
