Gday Gents
First time creating a build thread here and very green with the Nissan product
A bit of history and my back ground in cars has weighed heavily with Fords I own a FPV F6 Typhoon since 2008 this car didn't stay stock for long.
It has gone through a number of transitions over its life to be a very reliable tuff street car 730rwhp or 540rwkw
https://www.sau.com.au/forums/topic/458241-r33-gtr-vspec/
I then purchased a R33 GTST as a rolling shell off a friend at work This car came with everything bar a engine
me and my girlfriend at the time sourced a RB25 motor and began the build
We ended up running a T04 turbo and it made a mild 460rwhp on United P100
We had a heap of fun with this car at power cruise events and cruising but the bug had bitten hard I wanted more power but the car had massive traction issues as it was
Edited by frostyboy
https://www.sau.com.au/forums/topic/458241-r33-gtr-vspec/#findComment-7567886
After a bit of thought I realized that a GTST wouldn't cut it. I already had a big hp RWD car
It was time to find a GTR
Introducing the new project
1995 R33 GTR Vspec purchased as a roller off a bloke off the forums Matt Haines
Edited by frostyboy
  • Like 1
https://www.sau.com.au/forums/topic/458241-r33-gtr-vspec/#findComment-7567893
So went a bit crazy at the start. Bought a RB30 block and crank, CP pistons, spool rods ect but really forgot what I wanted out of the build
High reving twin turbo the 2.6L engine had that ability and I was about to throw a 3L at it I really want to do a 26/30 build however now was not the time first I needed to get the car on the road and experience what the RB26 could do
I picked up a low km rb26 engine which was running only 6 months before. It had some good bits in it
Poncams, eagle rods and CP pistons Picked up some -5 twin turbos and a vipec ECU
Planned on dropping it in and getting it licensed. But after a few interesting conversations some invaluable information was given to me which I'm glad I followed through with I went ahead and pulled the sump off and check all the bearings
Well I'm glad I did
Edited by frostyboy
https://www.sau.com.au/forums/topic/458241-r33-gtr-vspec/#findComment-7567987
After removing the intake plenum and throttle bodies The cylinder head ports were also very wet with oil and on closer inspection they didn't have brass valve inserts
The pistons on number 2 and 6 had massive pitting on the tops from destination
The bearings were made of a really soft material and chunks were missing out of them they were a very soft material so soft the chunks that have come away had not damaged the crank
Edited by frostyboy
https://www.sau.com.au/forums/topic/458241-r33-gtr-vspec/#findComment-7567995
So now a full engine build is a go the list of parts as follows
Ross Pistons
Eagle Rods
ACL race main bearings and big end bearings
ARP head studs and main studs
Tomei head gasket
HKS step 1 camshafts
Ported head with bronze/brass guides
N1 oil pump with billet oil pump gears
N1 water pump
Tomie sump baffle with trap doors
I purchased a Greddy plenum awhile back so throwing that on as well
https://www.sau.com.au/forums/topic/458241-r33-gtr-vspec/#findComment-7568241
Covers look great :)
Car is clean man, hope all goes well with the new engine!
Thanks man
The car is very clean. The engine bay has been repainted and cleared about 2 years ago so it's something I don't need to worry about
I have found a few bits and pieces that aren't right for this year car though
I found out the car has a R32 gearbox in it
It has a R32 ignition wiring harness in it so the ignitor is separate from the coil packs
It had various after market gauges and timers in it I have stripped them all out and am starting again
Doe anyone knows if these HKS knock boxe and timer are any good
Either way I pulled them out I think they may be missing components
https://www.sau.com.au/forums/topic/458241-r33-gtr-vspec/#findComment-7569018
    • As far as I can tell I have everything properly set in the Haltech software for engine size, injector data, all sensors seem to be reporting proper numbers.  If I change any injector details it doesnt run right.    Changing the base map is having the biggest change in response, im not sure how people are saying it doesnt really matter.  I'm guessing under normal conditions the ECU is able to self adjust and keep everything smooth.   Right now my best performance is happening by lowering the base map just enough to where the ECU us doing short term cut of about 45% to reach the target Lambda of 14.7.  That way when I start putting load on it still has high enough fuel map to not be so lean.  After 2500 rpm I raised the base map to what would be really rich at no load, but still helps with the lean spots on load.  I figure I don't have much reason to be above 2500rpm with no load.  When watching other videos it seems their target is reached much faster than mine.  Mine takes forever to adjust and reach the target. My next few days will be spent making sure timing is good, it was running fine before doing the ECU and DBW swap, but want to verify.  I'll also probably swap in the new injectors I bought as well as a walbro 255 pump.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
