So of course my stagea has to give me the shits while my other car is getting work done >.<
driving home today stopped at a light and when i took off again the car went about 10m then lost all revs so i pulled over, i have gathered its gone into limp mode and narrowed it down to a dead MAF!
The big question does anyone know where i can get a replacement in the northern suburbs melbourne? any help greatly appreciated.
Dave
https://www.sau.com.au/forums/topic/458459-help-p/
Dave
What car do you have?
https://www.sau.com.au/forums/topic/458459-help-p/#findComment-7573083
I used to sell them but ran out of stock. Try the part number in Ebay, there are heaps of aftermarket ones available that won't bugger up like the Nissan ones commonly do.
I am trying to find the reason the AFM faults, it's likely caused by low voltage I suspect. Have you popped the bung out of the battery compartment by any chance? That's where I would start. The large 2 inch bung gets blocked flooding the relay box causing all sorts of issues. Not sure if the AFM is related to this as yet, but it looks like it may be, at least you will have fixed a source of many other electrically related failures.
https://www.sau.com.au/forums/topic/458459-help-p/#findComment-7573089
What's your factory part number? It may well fit but they don't know so they say it doesn't to cover themselves.
Here's another one I found - does the factory number it quotes match yours?
http://www.trademe.co.nz/motors/car-parts-accessories/nissan/other/auction-920614276.htm
https://www.sau.com.au/forums/topic/458459-help-p/#findComment-7573170
Maybe the high voltage? I saw the voltage reach over 5v if run in height boost.
https://www.sau.com.au/forums/topic/458459-help-p/#findComment-7573204
the part number on the one i linked matches but that trademe one is different. I found one on ebay just before that someone else used in an m35 so ordered it :) hopefully it works
I bought 2 from eBay but all shit! One is dead after ran 10km. another one is still alive but the voltage is not same as stock one...so I can't use it. Finally I bought genuine one from Nissan with bloody price...so far so good for about 1000km
https://www.sau.com.au/forums/topic/458459-help-p/#findComment-7573207
Sorry to hear Yang, it did take me a while to find a suitable supplier for the aftermarket AFM's I used to sell. Amayama would have been a better option for genuine, but the shipping times from UAE aren't as good as the local Nissan dealership.
You are looking at the output voltage, not the input which is 12v. The AFM's have a processor inside which would likely fault if the voltage dropped too much, and the water in the battery compartment would be the obvious cause. A lot of us have had AFM's fail after or during rain too. Not saying it's definitely the cause of AFM issues, but it most certainly creates many other electrical issues. Pop that bung out before it leaves you stranded, it serves no purpose other than to keep dust out of there.
https://www.sau.com.au/forums/topic/458459-help-p/#findComment-7573222
Mines been playing up and im about to grab a new one. If after genuine amayama have australian stock 22680-6n21a for $110 + postage.. if you look up the original number the price is 5x that for some reason.. the replacement number above looks to have been used by people on here with sucess by searching the forum. if in more of a rush justjap have genuine stock for a few dollars more but still cheaper than half of the ones on fleabay...
https://www.sau.com.au/forums/topic/458459-help-p/#findComment-7573364
  • 3 weeks later...
well 2 weeks and its gone again... was a justjap one, in a bit of a bind now as i just totalled my other car >.< anyone know of any that aren't from Nissan in stock in Melbourne today or tomorrow?
much appreciated. if anyone can help pm me and i will get back to you straight away.
Dave
Edited by davidnsw
https://www.sau.com.au/forums/topic/458459-help-p/#findComment-7586681
Not really, the new Nissan PN just fails constantly, some of my customers went through 7 or more before fitting my aftermarket ones. Mine were lasting fine.
The original PN works very well, 15 years nearly in my case.
https://www.sau.com.au/forums/topic/458459-help-p/#findComment-7587393
why don't you sell your AFM again....LOL
my brand new genuine one lasts for 2month now. and I have 2 genuine AFMs with old PN in glove box....
Edited by YangLIU
https://www.sau.com.au/forums/topic/458459-help-p/#findComment-7587454
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
