R34 GTR Piston and rod, used less than 60k. $100 for 6
R34 GTR injectors, used less than 60k, $80 for 6
R34 GTR stock water pump, used less than 60k, $50
R34 GTR head bolts, M12. $30
R34 GTR stock fuel pump, same as nismo model. $60
R34 GTR front diff pinion and crown with diff center. 3.5454 ratio $200
RB front fan, mint cont. $50
R34 GTR stock turbo inlets $25
R34 GTR pull to push type conversion kit $50
R34 GTR stock crank pulley $30
R34 GTT front diff hubs good cond. $80
R34 GT4 front diff hubs, completed with upright. these will work with any GTR/GT4 front drive shafts and suspension components $150 for both
RB Exceedy heavy duty organic clutch, been sitting in the garage for some time, travel less than 10k. suit all RB motors $100
R34 GT4 air box completed. mint cond. $50
R34 GTR air inlet rubber hose $20
R34 GTR Turbo outlet top pipe $40
R34 GT4 Auto selector, off series 2 skyline, $40
R34 GT4 NEO Long motor. travel 100k, Auto box, great condition. motor already have oil drain hole, ready to be turboed Selling
NEO head: $400 Or
LONG motor with 4WD sump minutes diff crown and pinion $750
R33 GTR Vspec controller, with fuel pump controller together $40
R33/32 GTR power FC, no controller, off running car. no issues $450
RB26 AFM, have 3 available $50 each.
Items located melbourne. happy to post interstate.
Joe
0433289998
Edited by godsmind
no injector packs sorry. 34GT4 hubs sold pending payment.
also have the following:
R34 GTR front sway bar completed with rubber and links $130
R34 GTT front sway bar. sway bar only $40
R34 Front Reo bar. Good cond. $150
sorry selling piston and rods together:(.
will be $80 for rods only might as well take the pistons
Update
R34 GT4 front diff hubs, completed with upright. these will work with any GTR/GT4 front drive shafts and suspension components $150 for both SOLD
NEO head: $400 Or
R33/32 GTR power FC, no controller, off running car. no issues $450, PENDING PAYMENT
PS Someone take the motor please :touch:
R34 GTR injectors, used less than 60k, $80 for 6 SOLD
R34 GTR front diff pinion and crown with diff center. 3.5454 ratio $150
NEO head: $400 Or
R33/32 GTR power FC, no controller, off running car. no issues $450, SOLD
R34 GTR front sway bar completed with rubber and links $100
R34 Front Reo bar. Good cond. $100
Update
R34 GTT front diff hubs good cond. $80 Gone to God
RB Exceedy heavy duty organic clutch, been sitting in the garage for some time, travel less than 10k. suit all RB motors $100 Gone to God
R34 GT4 air box completed. mint cond. $50 Gone to God
NEO head: $400 Or
  • 4 weeks later...
  • 3 months later...
  • 1 month later...
NEO head: $400 Or
R34 NA Short motor 4WD sump minutes diff crown and pinion $400
R34 Front Reo bar. Good cond. $60
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
