so i had my car retuned a few weeks ago and the tuner noticed oil temp was consistantly high.
when it was last tuned and driven oil temp would sit at 80 degrees and now it sits between 90-100 when cruising at 100kph.
before the tune i switched from motul turbolight to penrite racing 10 10w40 and tidied up oil cooler (flipped how i installed it and moved temp sensor in line)
once the car has sat off for 10-15mins oil temp is back to 65-70.
engine:
built rb25 (2000km old, built by red r racing about 4.5 yrs ago) 6boost, gt3076 .82ex, greddy plenum, 1000cc xpurts.
nitto oil pump, rb20 oil block, mocal thermostat oil block (group buy kit), 19row setrab oil cooler (sits behind a opening in front bar), z145a filter
tuner has told me to use a thicker oil to see if that will solve the problem but i can't see how its gone from running normal to hot.
could there be another issue or changing the oil type will make that much difference?
and what oil should i try next? looking at penrite hpr10 10w50 or go back to motul?
What does your water temp do? Does your oil temp go nuts when you push the car hard? What does your oil pressure say at cruise? Always use Motul 10W 30 myself - if nothing else it can stand the heat .
Where have you moved the temp sensor from and too Rob?
The fact that youve played with the oil cooler and temp sensor makes me think either something is not right, or the temp sensor has moved from post cooler to pre-cooler
Sounds like it could be a plumbing problem. At cruise the oil shouldn't be getting hot enough to open the thermostat to send oil to the cooler. How have you got the cooler orientated in relation to the oil lines and are you sure the thermostat is plumbed correctly?
This
Cal it's in one of the oil lines, just removed some of the adaptors I was using.Will swap it to the other line and see if there is a difference.
Oil cooler is mounted with inlet and outlet facing up. I rotated the oil block 90 degrees so fitting now faces downward and thermostat is horizontal.
Will remove the thermostat and check. Oil is getting to the cooler as it is getting hot.
Edited by robbo_rb180
If it is a temp issue (as opposed to sensor/gauge ect), picking up a bearing can result in high oil temps at low rpm/load.
Post some pic's of the oil cooler set up.
Cheers
J
Edited by XRATED
either would I, but IF he's is getting hotter than usual oil temps- just cruising...
I agree, it's more than likely a gauge/sensor re-location change that is displaying different temps.
I run the same oil (Penrite 10w40) and my oil temps sit at 70-80 when cruising and giving it stick on the road and only hits 90-100 when on the track. This is in Darwin heat too so could be more than likely gauge/sensor
  • 3 weeks later...
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
