so i had my car retuned a few weeks ago and the tuner noticed oil temp was consistantly high.
when it was last tuned and driven oil temp would sit at 80 degrees and now it sits between 90-100 when cruising at 100kph.
before the tune i switched from motul turbolight to penrite racing 10 10w40 and tidied up oil cooler (flipped how i installed it and moved temp sensor in line)
once the car has sat off for 10-15mins oil temp is back to 65-70.
engine:
built rb25 (2000km old, built by red r racing about 4.5 yrs ago) 6boost, gt3076 .82ex, greddy plenum, 1000cc xpurts.
nitto oil pump, rb20 oil block, mocal thermostat oil block (group buy kit), 19row setrab oil cooler (sits behind a opening in front bar), z145a filter
tuner has told me to use a thicker oil to see if that will solve the problem but i can't see how its gone from running normal to hot.
could there be another issue or changing the oil type will make that much difference?
and what oil should i try next? looking at penrite hpr10 10w50 or go back to motul?
What does your water temp do? Does your oil temp go nuts when you push the car hard? What does your oil pressure say at cruise? Always use Motul 10W 30 myself - if nothing else it can stand the heat .
Where have you moved the temp sensor from and too Rob?
The fact that youve played with the oil cooler and temp sensor makes me think either something is not right, or the temp sensor has moved from post cooler to pre-cooler
Sounds like it could be a plumbing problem. At cruise the oil shouldn't be getting hot enough to open the thermostat to send oil to the cooler. How have you got the cooler orientated in relation to the oil lines and are you sure the thermostat is plumbed correctly?
This
Cal it's in one of the oil lines, just removed some of the adaptors I was using.Will swap it to the other line and see if there is a difference.
Oil cooler is mounted with inlet and outlet facing up. I rotated the oil block 90 degrees so fitting now faces downward and thermostat is horizontal.
Will remove the thermostat and check. Oil is getting to the cooler as it is getting hot.
Edited by robbo_rb180
If it is a temp issue (as opposed to sensor/gauge ect), picking up a bearing can result in high oil temps at low rpm/load.
Post some pic's of the oil cooler set up.
Cheers
J
Edited by XRATED
either would I, but IF he's is getting hotter than usual oil temps- just cruising...
I agree, it's more than likely a gauge/sensor re-location change that is displaying different temps.
I run the same oil (Penrite 10w40) and my oil temps sit at 70-80 when cruising and giving it stick on the road and only hits 90-100 when on the track. This is in Darwin heat too so could be more than likely gauge/sensor
  • 3 weeks later...
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
