nah they arent well i dont think they are.
You be the judge.
just wanting to know best way to go about turboing this car. like sort of turbo etc, ive got a fair idea on what i need:
exhaust manifold
turbo
oil feed and return line
ecu
intercooler and piping
fuel pressure reg
and so on, just need an opinion of someone who has been around nissan motors
Start saving for pulsar gtir. They're worth f**k all these days anyway
There's a reason most are cheap.
You got pulsar questions?
PGA is dead, but there's a lot of people on the Facebook page.
Otherwise SR20-forum.com is the place to go. N14-15 is similar to B14 sentra.
Also I've rambled on about basic pulsar mods on ozpulsar.com.au
yeah I was gong to suggest a GTI-R too, they have the best version of the SR20, big factory intercooler, proper awd driveline, etc
finding a good one will be the painful part, most have been trashed to death. barely see them anymore
Sorry but that's incorrect. Everyone goes VE for a reason.
I'm doing my last 54C (gtir) build now. Never again. Parts getting too hard to find with little benefits.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
