I've been getting some minor things put together to start refurbishing the interior of my R32 gtr.
I have a few questions before I start tearing the inside apart. What material is used underneath the faux-leather the dashboard, door panels, and rear upper and lower interior quarter panels? I'm lead to believe they are plastic, not fiberboard, if i'm not mistaken?
https://www.sau.com.au/forums/topic/459091-interior-upgrade/
Never poked around the r32's but all Nissans of the early to late 90's era would have a plastic dash and door panels covered with vacuum formed vinyl and a thin layer of foam underneath
The other trim pieces, especially the smaller stuff, would just be textured plastic
Personally I think it will look like arse when all together using the Gater stuff except the Handbrake boot and gearstick boot.
Go the Nismo seat covers. They are really good. A+
A, B, C panels are plastic and the c pillars can be very brittle - be careful on removal.
All clips break easily
As for the doors they are compressed fibre type timber or as you put it fibreboard.
the heat from a heat gun will remove pretty much all the vacuum sealed material. Getting the glue off is a different matter. Mineral turps or similar and a lot of rubbing
I hope it turns out well for you
I'll do very small pieces at a time. Also, now that I know, i won't use the Gaiter stuff. What are y'alls opinion on just repairing the dashboard instead of tearing it apart? A new dashboard is too expensive.
Edited by Velict
Something you may wish to try first.
Remove the material inserts on the front doors and rear passenger panels. clean the glue residue off with turps
Get a reasonable quality interior paint pressure pack (or 2) of the closest colour to the interior door colour you can find.
Remove door cards and rear cards and spray. Let dry and replace.
Labour and about $50 bucks.
Win/Win
I'll worry about a full recover some other time. I guess the dashboard will be the last thing to get work done to it, (since of it's price)
I replaced the speedo cluster facia today with a new one. Looks great. But, the switches actually have bulbs in them! I didn't know this. Does anyone have a proper LED replacement for the TSD 077 3mm incandescent bulbs? Maybe a guide that someone can point me to? Thanks in advance.
Im always a bit dubious about ebay 'upgrades' like this. The interior is one of those things where if you dont spend the proper amount of money it really shows.
Im in the process of tidying up my interior too. And spent a small fortune on renewing certain areas and im not quite finished yet.
Just remember you get what you pay for and 'bolt on' is never quite what it seems
yeah im very dubious about how those ebay things will look in real life.
even top gaiters can be hit and miss, i got a gearstick boot which was a bit off. good condition genuine parts almost always look best unless your spending propper money of good materials made to fit.
and if your doing something customer i would always go for good material.
like alcantara or flocking a dash mmm
yeah i believe my car has a ebay spec gear stick and handbrake trim. looks cheap AF. i will end up buying these new from nissan. i only have a small list to go until my interior is respectable. the item i can tolerate is the dash. its about 95% in good condition. i am tossing up between looking for a good original or flocking it. also tossing up between a genuine nardi deep corn or retrimming the factory gtr wheel.
I would recover the dash with new vinyl. quite a common job with old cars, they use pretty much the same vacuum process as the factory. as long as the colour and grain are close, the result will be pretty awesome and better than stitching pieces together and ending up with wonky seams and bulges
here is an example:
http://dashboarddoctor.com.au//beforeafter.html
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
