everytime i have been to the drags on wed night people leaving always drive like idiots.
This feeds the "Cops harass me" arguments.
(Note; Not discounting harassment, i know it happens but sometimes its asked for.)
The road surface is less gripper then the 1/4 mile track. Hence it doubles or sometimes triples their car's power output which makes it easier to chirp 2nd gear leaving the gate.....and then straight into it for some.
The only reasonable logic I've come up with so far..
the car park must have the same problem, after seeing people attempting launches one afternoon.
  • 4 weeks later...
I have been to the last few eomm.. you get your normal propper car enthusiasts and people that want to hang and talk shit.. then you get dickhead p platers trying to go one up on eachother.. who has the biggest grill speakers or does the maddest single pegger..
End of the day doesn't matter where you go f**kwits will be there
  • Like 1
