Just a quick question, i have a neo head getting reconditioned at the machinist and bought some 260 9.15 tomei poncams to drop in,
Initially was told as long as the springs are the same height when measured that they should be ok which ive been told they are, but now told that the retainers are a high risk piece that will likely crack and ill drop a valve, so i should replace the springs and retainers with quality stuff like supertech... this makes sense but plenty of unopened RB's around and usually its a blown ring landing i would of thought.
Goal with build- area under curve 320ish, street car, 20psi max/ 14psi daily, 6500rpm limit, stock RB30 bottom
So is all that true or just trying to work the bill up???
https://www.sau.com.au/forums/topic/459673-neo-valve-springs-and-retainers/
    • I thought it could be an issue because the standard plate was flexing when stressed. Maybe the original gear set will hold a bit better without flex? Last time on the dyno it made around 670nm at the hubs. Now it have bigger turbo and better intake but have not been on a dyno yet. The car is being used from family trips to drag race events. So the shifts can be a little violent. It is grinding if I shift to fast so was thinking I should overhaul it soon.
    • From the factory on RB26s there's a fitting on the intake manifold collector/"plenum" that provides pre-throttle boost signal. That's how they did it back in the day, I figure it's fine to replicate it.
    • I would be surprised if that wasn't the issue. It's probably telling you, that even if you remove the plastic liner, you may have some other clearance issues that may occur too in some scenarios. IE, tyre to guard. It looks like someone has already rolled the lip, but you may still have issues in the future IE, turning and hitting a bump etc. The fact it changes how bad it makes the noise when you are going backward vs forward is highly indicative that it's the tyre rubbing. They do make a terrible sound, even if you're only pushing a project car that has a liner hanging down on a tyre!   Has the car been lowered? If it has been, what is the measurement from the centre of the wheel hub to the lip of the guard straight up?
    • Summernats cruiser?
    • Mark's a bit smarter than people give him credit... He'd convince the person that is to become dead, to drive him to the forest first. That way his car has no evidence in it, and he's free to dispose of their vehicle permanently how he sees fit too...
