Does anyone know if the jdm 370gt has the tyre pressure thing going on?
Had someone who could read Japanese tell me there was an option in the speedo display that said tyre?
But had the tyre off the rim n no sensors unless some retard discarded them somewhere along the line.
Will soon be fitting q60 cluster so I can sus all the shit in there out.
https://www.sau.com.au/forums/topic/459874-tyre-pressure-sensors/
No idea about the TPS. But fyi I think it is a HUGE leap to assume that a Q60 cluster will be a plug and play affair on a V36 - the wiring differences between USDM G35s and JDM V35s were pretty significant in some areas - I would imagine the V36 vs Q60 would be the same level of differences.
Got a guy in Europe who has checked schematic on both models pretty much the same,us models yes massive difference as to why he has made up new harness for my English conversion complete swap out of gear with with updated software to 2014,new buttons,new navi unit with Aussie maps,new heater n stereo buttons,gives me Bluetooth streaming n heaps of stuff,works sweet,was a few grand but it's the bomb.
As for cluster all it is is a slave
Was just going to use the lcd from it but I like the look of the q60 cluster
The only f**k around is the eprom chip that needs to be removed and re soldered into the q60 cluster to keep mileage.
Wow, nice work there Justin - looks like you have really done your homework! Also looks like when I buy a V36 in the near future I need to take it to you and get a conversion package done on it :)
Oh man I tell u the amount of emails and conversing that's been done is ridiculous.
I'd spoke to a few people in Aus about n I got such a mixed bunch of theory's and opinions.
Some people wer installing the Aus map n using stickers on the jap buttons,personally I think that is chat looks unprofessional n a bit tacky.
Some said I couldn't do it with any v36 under 2010 some said it was a 10k exercise etc
And I read all the convos on here n was pretty confused about the whole thing.
But like this guy said we arnt driving nasa ships lol
U just need to know what your doing and have the right resources.
Although it's not cheap at all I think it's worth it,considering how beautiful these cars are and for resale also people can enjoy the full potential of the car.
The English kit was $3080 and q60 cluster from Infiniti in Melbourne is $1100.
Thanks talkiet.
Makes sense now as I read about the service thing u can set.
I'm waiting on some more info but I'm hoping to adapt it to mine as the 2014 q60 set up has it I'm pretty sure,it's just a matter of if the in dash unit has the frequency pick up inbuilt or if it's an external stand alone unit integrated with the system
Yeah no worries
There has been a few hic ups like the wheel camera but we found that the fx37 have a wheel camera so we are using that button cluster as it has the camera button in the same place and actually sez camera and fx37 unit and stereo climate button panel
As for the TPMS I just received info that it is a seperate unit that is easy to get and easy to instal although it needs to be programed into the bcm which I think might be a bit of a task.
I'm waiting on a definite if it is possible to be programed into it,if it's a yes I have a tech at Brookvale Nissan who's Ment to be the best in the country who wins the annual "tech off" every year sonic been told.
I'm yet to speak with him about the mileage correction as u can also re program that so the q60 cluster mimics the mileage of the jdm cluster,in a sense it seems easier than getting a temp controlled soldering iron and swapping out the eprom chips.
I mean that's if he is clued on programming a cluster,there is also blokes out there who run instrumentation company's for this type of work which I'll look at if the Nissan guy isn't confident.
Ok so yes it can be programed into the bcm once sensors are in and installed and control modual is in same as speedo can have mileage done using consult 3
Was just at Nissan Due to legal reasons they can't do cluster mileage unless it's a warentee job and dont really want to set up the TPMS they said it could be done but it would just take them ages which will cost heaps.
So bin that idea
My guy uses consult 3 also but really knows how to use it.
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
