Short video I put together of the Drift school hosted by Drift Techniques at Tailem Bend South Australia
Unsure if correct place mods please move and advise if I have done goofed
  • Like 4
https://www.sau.com.au/forums/topic/459928-drift-techniques-tailem-bend-video/
Looks like awesome fun! Nice editing too
cheers mate. really good day there and lots of one on one time with top notch drivers including Stewy Bryant and Simon Michaelmore
we need one of these days in Sydney
they were thinking of bringing the schools to other tracks around the country if there was enough interest. the tailem bend ones were ~$200 for the day 8:00am-4:00pm max of 30 drivers but usually only ~20. so lots of seat and track time
  • Like 1
Interested!!
there are two already.... the original "drift school' is based in sydney.
http://hitecdriftschool.com.au/or same place parent site http://driftschoolaustralia.com.au/
we need regular days like this in Tassie.
Drifting isn't allowed outside of official drift events on either track. Clear open area technique practice/development opportunities done legally exist.
J
