Doesn't matter they will still put the engine number onto your rego papers by doing what I said
The current rta rule is you can increase the engine capacity by 20% without needing an engineers cert as long as the engine is from the same family as the original
The current rta rule is you can increase the engine capacity by 20% without needed and engineers very as long as the engine is from the same family as the original
If they put the rb30 engine number, will he then get defected for having an rb25det setup attached to it?
No because he requires the pollution gear from the r33 to be fitted to it, if he removes the pollution gear from the car then he can be defected for not having that but not for the bottom end being changed.
It's the same as fitting an ls3 into a car that had an ls1
  • 8 months later...
and now to add to that, there is also a limit of 20% increase over factory power output too, see point 2 on page 3
http://www.rms.nsw.gov.au/documents/roads/safety-rules/standards/vsi-06-light-vehicle-modifications.pdf
however if someone was to have a dyno sheet with a run done at say 50% throttle you could say hey look this is proof that the motor makes less power than the standard rb25det
Pea shooter exhaust, cam gears retarded, 7psi (or a boost leak), tune with no timing
Lots of ways to reduce power for engineering.
I drilled a hole in bung I'd used to block blow off valve to create a boost leak and passed wa pits with a setup that made twice the standard power.
  • 1 month later...
yeah but the block is older than the car
Emissions controls for the Rb are all related to the head.
Mine was engineered with a high mount gt35 and 3.5" exhaust (big mufflers, no cheats to make it quiet), but mine was done years ago and I also had to go get it emissions tested. E85 and a nice big 400 cell cat or two helps make that easier.
    • Congrats on the career change!  I did something similar at the start of the year too, left IT / corporate after nearly 2 decades. Soooo when's the motor coming out for the spark plug change?
    • Hi guys, long time no post as per usual! It's been a busy year so far, the biggest thing being a new job.  After 28 years in the automotive industry I decided it was time for a change.  I was losing faith in the industry and where it's heading.  Now in a completely different industry (electrical) working for a company that manufacture water pump contollers.  Not as sexy as cars but it's an interesting,  challenging industry. I now don't work Saturdays which is a bonus!  It's still 50-55 hours a week but having Saturdays ack after 28 years of working them is awesome!   No news on the GT-R but i did decide to add some more JDM goodness into my life....           1990 300 ZX.  She's not perfect but for a 35 year old car she ain't bad!  Just going to tidy it up a bit and enjoy it.  It's currently auto but will start stockpiling everything for a manual swap. It WILL distract me even further from the GT-R but im hoping not for too long! It somewhat proves a 6'8" freak can fit in a 300 ZX.  Sort of...  I drove it home from the previous owners house in Melbourne via Black Spur and Merton Gap (2 awesome bits of Victorian twisty road) and it was amazing!  Handles so well!!!   I don't think it would be worthy of a full build page but I'll post up some of the upgrades here if anyone is interested?  Cheers guys!
    • End game is to: - Remove all the slop from old worn parts - Adjust setup so that the wheels actually fit and the car is drivable (currently it is not because of the extreme rubbing on the guards).   Progress over the last couple of days, removed the rear hubs! Next steps: - Buy bushings - Replace bushings/bearings on hub - Reinstall
    • Cracked deck  And other cam snap stuff
