I wonder what the fastest time for a White Series 2 R33 GTS-t with HKS GT3040, Tial 46mm Wastegate, PowerFC, Trust Type-R BOV, Plasmaman Intercooler, GReddy Intake Plenum, Sard 660cc injectors, NGK Plats, running 1.2 bar, using 235/40/17 Dunlop D01Js, and a Cusco carbon fibre strut bar is?? :confused:
They're the category rules, no changes... They sound like a great set of legal modifications to base the class around.
I think I might have been the world's fastest!!!!
:spcow: :spcow: :spcow: :spcow: :spcow: :spcow: :spcow:
I ran 11.10 @127 a few years ago with low mount 2540s on std internals engine.
Of course after the next meeting the internals were stuffed so didnt last long.
From memory was making about 345 rwkw at that stage.(before it went bang)
We did push it as high as 395 rwkw on C21, but didnt race it on that tune due to obvious
reasons. On a 'built' engine, should be able to run around 400 rwkw or more with good low mounts without any problems. Of course then driveline explosions become the limiting factor.
Guest two.06l
Thanks guys for all the comments. Found out that the Australian record for a low mounts is 10.78 @ 130.33mph, by Theo in QL with his white 32 GTR. The world record is 10.6?, Mines white 34 GTR (6 speed). (although I cant find any info to actually be 100% positive of this one).
:wavey:
Guest two.06l
So you're going for the records for low mounts?  Aussie then world?  WTF??!?!!!?!?!?!
Adrian
Adrian, why all the negativity?? I thought this forum was to create discussion and support between people who love skylines? Seems that all you have ever done to me is rip me off!!! At least I get out there and have a go.
Guest two.06l
Stace honestly take it with a grain of salt, put it down to Imacrabbyf*cker syndrome because I can't race at the moment hehehe I know this because i've had it for the last few months aswell :)
Thanks Buster I can always rely on you for some encouragement. You always respect others on the forum even if you don't agree with what their saying.
All we have done to the car has been in our shed at home, no big name workshop or big $$ budget, sure great times earn respect and obviously I have not reached the cars potential yet.............or mine.............but I'm the only girl I've seen entered in the import catergory and I'm not afraid to get out there and have a go......and remember 2rismo I'm only 0.2 sec behind you, so look out!!
BTW....... what Adrian does'nt realise is I have a secret weapon, and his name is paul. He can drive the pants off that car, and I'm not afraid to predict that paul will have broken at least one of those records before the end of the year. We even have the support and assistance of one of the current record holders to help us achieve this. That's what I call sportsmanship!
Wwwwwwhhhhhhhhoooooooo!!!!!!!!!!!!!!!!!!!!! it's out there now
No no no no no.... That was meant to read: "So you're going for the records for low mounts? Aussie then world? WTF??!?!!!?!?!?! i.e. Big plans coming up for the car!!! Holy shit I had no idea of your intentions - good luck etc etc etc...."
I'm not taking the piss, Stace. Really.
Adrian
"Hello, is the 'real-life' Adrian out there?"
No. He ran an 11 or two then gave up :)
Really, it just lost something (and gained something) in the translation, Stace. Only 0.2 seconds behind me? Shit a brick! New low mounts AND coconut sunscreen?!?!?! I am FINISHED! hehehe...
Adrian
Guest two.06l
You can stop loving yourself in here please Brett :)
Seriously though Stace, I'm not taking the piss or being negative.  I'm a DIRT groupie and you know it :)
Adrian
DIRT Garage has it's first groupie. This is great news. Thanks Adrian. I will sleep better 2nite.
Go the DIRT!!.
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
