Carbon Fibre Group Buy #3 R32 R33 R34 Etc *** New *** 10/25/2015
that one pic below....
any pics and dimensions of the wings plz?
Hey what style is this ? the bodykit
Universal Spoiler's
Universal GT Wing Type-A (Length:1440; Width:280; Height:260; Leg Distance: 580 or 640)
Universal GT Wing Type-B (Length:1410; Width:270; Height:260; Leg Distance:555)
Universal GT Wing Type-B1 (Length:1380; Width:230; Height:260; Leg Distance:890)
Universal GT Wing Type-A1 (Length:1420; Width:230)
Universal GT Wing Type-E (Length:1450; Width:260)
Universal GT Wing Type-D (Length:1500; Width:260)
Universal GT Wing Type-C (Length:1450; Width:240)
Universal Type- AS GT Wing (Length:1450mm; Height:250mm)
Universal GT Wing (Length:1700mm ; Height:300mm)
Universal GT Wing Length:1700mm ; Height:180mm)
Alex : Around $500-550
Mr_rbman : about $150 + $30 freight to you're door
  • 1 month later...
  • 5 weeks later...
On 9/5/2016 at 10:23 PM, Goliath101 said:
Anyone heard from Longz? Still waiting on an item ordered in November last year.
He normally replies to Pms within a couple days.
  • 1 month later...
Same boat here, would appreciate some reply.
  • 1 month later...
Hey Longz,
Any R34 GTR stuff left?  I'm after a rear wing blade, the wing end caps and side skirts.  All in carbon please
  • 1 year later...
Hi all if we can put abit of a list together and i will see the best price i can get on a group buy and if cheap enough and all is happy we can go from there.. i can honestly say that as i and my family purchase a fair bit i think we all will get a good price.. Cheers and lets have a great 2018 and a safe one too..
Hi again... i will write down all the things we all want and to start off lets give it 2 weeks or so then if enough i will see what prices we can get and go from there.. as if cheap enough afew more may jump on board for more items then prices can only get cheaper..... Cheers for now
  • Like 1
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
    • Not sure yet.  Was considering speedtek because it was rated to 800hp, but when I did some research about him I don't think I will go for that🤣 So maybe giken gear set, but I'm afraid it won't be strong enough🙄
