timmy_89 Posted October 28, 2015 Share Posted October 28, 2015 Hi all, You may already be aware, Alpha Omega Racing have been developing adaptor kits to fit front Evo Brembo’s to S/R/Z chassis for some time now. As some of you are aware, they have recently finished development and testing of their rear kits, creating a cost effective way to get some bigger brakes on the rears of our cars. Alpha Omega Racing recently ran a group buy for the front kits and is now offering a group buy on the new rear kits, as well as a second round group buy on the front kits (now Version 3). The new version for the front kit means that now both front and rear are completely bolt-on (except for the dust shields being trimmed). The front kit previously required you to cut a tab off the hub. They are also stronger with the new design. Company: Alpha Omega Racing www.alphaomegaracing.com Products: Evo 350mm Brembo Front Brake Adaptor Kit and/or Evo 350mm Brembo Rear Brake Adaptor Kit. These adaptors are 100% CNC machined billet alloy, grade 7075, which is super lightweight and high strength. Fitment with 18x10 +15 What's included (front kit): - Left and right adapters made out of one piece of 7075-T6 billet aerospace alloy - Various high tensile 12.9 bolts and high tensile washers - Full installation instructions with pictures Front fitment with 17x9 +15 What's included (rear kit): - Left and right adapters made out of one piece of 7075-T6 billet aerospace alloy - Hub spacers - Various high tensile bolts and high tensile washers - Full installation instructions with pictures Rear fitment with 18x10 +35 What you need to get (front kit) - B.Y.O. or supplied by Alpha Omega Racing: - Mitsubishi Lancer Evo 5/6/7/8/9 Brembo frontcalipers(including pads/pins/shims/clip) - Mitsubishi Lancer Evo 10 front 350x32mm rotors - Custom brake lines Alpha Omega Racing can supply all of the above parts, but you also have the options of sourcing them yourself. I personally sourced parts for my front kit elsewhere as I had my own lines made and picked up a cheap set of calipers. Alpha Omega Racing has these parts listed at: - Mitsubishi Lancer Evo 5/6/7/8/9 Brembo frontcalipers (used) - $850 - Mitsubishi Lancer Evo 10front350x32mm DBA T3 rotors (new) - $470; or - Mitsubishi Lancer Evo 10front350x32mm DBA5000 2pc (new) - $1200 - HEL custom braided brake lines (new) - $130 What you need to get (rear kit) - B.Y.O. or supplied by Alpha Omega Racing: - Mitsubishi Lancer Evo 5/6/7/8/9 Brembo rear calipers (including pads/pins/shims/clip) - Nissan 370Z rear 350x20mm rotors - Custom brake lines Again, Alpha Omega Racing can supply all of the above parts if desired. I personally sourced all parts from Alpha Omega Racing for convenience with the rear kit. Alpha Omega Racing has these parts listed at: - Mitsubishi Lancer Evo 5/6/7/8/9 Brembo rear calipers (used) - $450 - Nissan 370Z rear 350x32mm DBA T2 rotors (new) - $450 - HEL custom braided brake lines (new) - $110 Silvia (180SX/S13/S14/S15) drivers who want a functioning hanbrake will need to use the R32/R33/R34/Z32 rear drum setup, a very common upgrade. It is also worth noting that the rear kit requires a 6mm hub spacer to be installed for caliper clearance, this will also push your wheel/tyre out a further 6mm so may affect guard clearances. Alpha Omega Racing can also offer services to rebuild your used calipers, powder coat them, or even install the whole kit. Using both the front and rear big brake kits developed by Alpha Omega will result in a 69:31 brake bias. Wheel clearance: Minimum of 17" race style wheels with good clearance are required. Brake Master Cylinder: You are able to retain your factory brake master cylinder, however it is recommended to upgrade to a brake master cylinder with a piston size of 17/16" (such as a BM57). Genuine OEM BM57 BMC’s are available from Alpha Omega Racing at a price of $500 (new), or you could also try to source from your usual Japanese parts suppliers or Nissan dealership if you desired. Price: The RRP for the front adaptor kit is $370 plus shipping, while the rear adaptor kit is $450 plus shipping. The group buy discount will be based on total number of kits being purchased, not the number of buyers, and will apply as such: - <5 kits = no discount - 5-11 kits = Front kit for $340ea, rear kit for $420ea, ($30 discount + free shipping) - 12-19 people = Front kit for $310ea, rear kit for $390ea, ($60 discount + free shipping) - 20+ people = Front kit for $280ea, rear kit for $360ea, (90 discount + free shipping) Alpha Omega Racing also offer packages with the adaptor kits and other required parts. They provide discounts on normal pricing, but will also be offered with the $30/60/90 discounted pricing of this group buy based on numbers, meaning a further saving. These packages are: - Half kit – includes the adaptor kit and custom brake lines Front – $449 (reduced from $500) less group buy discount Rear – $499 (reduced from $560) less group buy discount - Full kit – half kit, plus calipers (used) and DBA rotors Front – $1649 (reduced from $1820) less group buy discount Rear – $1299 (reduced from $1460) less group buy discount - Boss kit – full kit, plus full rebuild kit/service and powder coating of calipers Front – $2179 (reduced from $2400) less group buy discount Rear – $1709 (reduced from $1930) less group buy discount Fitment with 18x9 +30 Group Buy Condition: The group buy will run for a two (2) week period, finishing at close of business on 11th November 2015. Anybody interested in purchasing either of the kits/packages as part of the group buy should notify me by the cut-off date and I will add them to the 'buyer list'. At the conclusion of the group buy period I will tally the number of buyers and advise Alpha Omega with the total numbers. A discount ‘coupon code’ will be provided to each buyer allowing them to get the appropriate discount in the shopping cart on the Alpha Omega Racing website. NOTE: Group buy is a PRE-ORDER and will have an approximate four (4) week wait between payment from all parties and delivery. Prior to the cut-off date all communication will be with me either via this thread or via PM. At the conclusion of the group buy, once you have been provided with the discount code, all communication will be between the buyer and Alpha Omega Racing. All shipping and payment details will be between the buyer and Alpha Omega Racing only. Any warranty on the product(s) will be provided by Alpha Omega Racing. Extra Pictures: Front fitment with 18x10 +35 Fitment with 18x8.5 +36 Front fitment with 18x9.5 +12 Rear fitment with 18x9.5 +12 Yellow S15 fitment with 18x10 +11, silver S15 fitment with 18x9.5 +22 If you have any questions, regarding the kit or the pricing, please don't hesitate to ask either by posting in this thread or sending me a PM. Cheers, Tim Link to comment https://www.sau.com.au/forums/topic/460654-alpha-omega-racing-evo-350mm-big-brake-kit-group-buy-round-2/ Share on other sites More sharing options...
GTR_JOEY Posted October 29, 2015 Share Posted October 29, 2015 Point to note: The black 32 is mine and I have a 33 rear subframe which makes the rears stick out a bit more 2 Link to comment https://www.sau.com.au/forums/topic/460654-alpha-omega-racing-evo-350mm-big-brake-kit-group-buy-round-2/#findComment-7628031 Share on other sites More sharing options...
timmy_89 Posted October 29, 2015 Author Share Posted October 29, 2015 There is also one person confirmed already Link to comment https://www.sau.com.au/forums/topic/460654-alpha-omega-racing-evo-350mm-big-brake-kit-group-buy-round-2/#findComment-7628041 Share on other sites More sharing options...
Ad's Posted October 29, 2015 Share Posted October 29, 2015 Will let you know in the up comming days Timmy. Sussing what funds I might have before my tune!!! 1 Link to comment https://www.sau.com.au/forums/topic/460654-alpha-omega-racing-evo-350mm-big-brake-kit-group-buy-round-2/#findComment-7628075 Share on other sites More sharing options...
flovv Posted October 31, 2015 Share Posted October 31, 2015 Hi, I want one front half kit for a gtr33 and one for a gtr34. /Stefan 1 Link to comment https://www.sau.com.au/forums/topic/460654-alpha-omega-racing-evo-350mm-big-brake-kit-group-buy-round-2/#findComment-7629696 Share on other sites More sharing options...
brento Posted November 1, 2015 Share Posted November 1, 2015 Put me down for 1 x front half kit and 1 x rear half kit. Thanks 1 Link to comment https://www.sau.com.au/forums/topic/460654-alpha-omega-racing-evo-350mm-big-brake-kit-group-buy-round-2/#findComment-7630064 Share on other sites More sharing options...
timmy_89 Posted November 1, 2015 Author Share Posted November 1, 2015 That makes 5 kits currently people, group buy discount is on! Current saving is $30 per kit, if we get to 12 that discount will be doubled Link to comment https://www.sau.com.au/forums/topic/460654-alpha-omega-racing-evo-350mm-big-brake-kit-group-buy-round-2/#findComment-7630069 Share on other sites More sharing options...
luke gtr Posted November 5, 2015 Share Posted November 5, 2015 How long will the code last for? May or may not be getting cash. If I do, doubt it will be around the 11th. More likely the end of the month. Will know if I can go ahead in the next week. And would be getting front and rear kits. So, NOT CONFIRMED YET. but, should know soon. Link to comment https://www.sau.com.au/forums/topic/460654-alpha-omega-racing-evo-350mm-big-brake-kit-group-buy-round-2/#findComment-7632542 Share on other sites More sharing options...
timmy_89 Posted November 5, 2015 Author Share Posted November 5, 2015 How long will the code last for? May or may not be getting cash. If I do, doubt it will be around the 11th. More likely the end of the month. Will know if I can go ahead in the next week. And would be getting front and rear kits. So, NOT CONFIRMED YET. but, should know soon. Will shoot you a PM Link to comment https://www.sau.com.au/forums/topic/460654-alpha-omega-racing-evo-350mm-big-brake-kit-group-buy-round-2/#findComment-7632569 Share on other sites More sharing options...
acr Posted November 8, 2015 Share Posted November 8, 2015 I will grab a half kit for r32 gtr if its not to late. Contact No. 0406769404 email. [email protected] Thanks, Alex Link to comment https://www.sau.com.au/forums/topic/460654-alpha-omega-racing-evo-350mm-big-brake-kit-group-buy-round-2/#findComment-7634516 Share on other sites More sharing options...
timmy_89 Posted November 8, 2015 Author Share Posted November 8, 2015 I will grab a half kit for r32 gtr if its not to late. Contact No. 0406769404 email. [email protected] Thanks, Alex Not too late, cut off is close of business on the 11th November. Added you to my list , where you after a front of rear half kit? I will send all confirmed parties a final confirmation PM on the night of the 11th, before providing them with a discount code from Alpha Omega Currently 6 confirmed kits, 2 more maybes. Link to comment https://www.sau.com.au/forums/topic/460654-alpha-omega-racing-evo-350mm-big-brake-kit-group-buy-round-2/#findComment-7634542 Share on other sites More sharing options...
acr Posted November 8, 2015 Share Posted November 8, 2015 Front half kit. Thanks 1 Link to comment https://www.sau.com.au/forums/topic/460654-alpha-omega-racing-evo-350mm-big-brake-kit-group-buy-round-2/#findComment-7634705 Share on other sites More sharing options...
timmy_89 Posted November 10, 2015 Author Share Posted November 10, 2015 Final numbers to be supplied to Alpha Omega Racing tomorrow at 6pm. Anyone else keen on getting in on this pleasee let me know before then. Link to comment https://www.sau.com.au/forums/topic/460654-alpha-omega-racing-evo-350mm-big-brake-kit-group-buy-round-2/#findComment-7636140 Share on other sites More sharing options...
luke gtr Posted November 10, 2015 Share Posted November 10, 2015 Won't be able to confirm by tonight, so I'm a no go. May have to wait for the next gb. Post pics when you've installed people Link to comment https://www.sau.com.au/forums/topic/460654-alpha-omega-racing-evo-350mm-big-brake-kit-group-buy-round-2/#findComment-7636167 Share on other sites More sharing options...
flovv Posted November 10, 2015 Share Posted November 10, 2015 Hi, I want one front half kit for a gtr33 and one for a gtr34. /Stefan Not sure that the owner of the gtr33 is still in. When is the deadline? /Stefan Link to comment https://www.sau.com.au/forums/topic/460654-alpha-omega-racing-evo-350mm-big-brake-kit-group-buy-round-2/#findComment-7636239 Share on other sites More sharing options...
timmy_89 Posted November 10, 2015 Author Share Posted November 10, 2015 6pm today (9hrs) Link to comment https://www.sau.com.au/forums/topic/460654-alpha-omega-racing-evo-350mm-big-brake-kit-group-buy-round-2/#findComment-7636242 Share on other sites More sharing options...
timmy_89 Posted November 11, 2015 Author Share Posted November 11, 2015 Group buy is over guys. Pm'ing all people who stated they wanted a kit(s) to confirm numbers and emailing Alpha Omega Racing. Link to comment https://www.sau.com.au/forums/topic/460654-alpha-omega-racing-evo-350mm-big-brake-kit-group-buy-round-2/#findComment-7636915 Share on other sites More sharing options...
timmy_89 Posted November 13, 2015 Author Share Posted November 13, 2015 Group buy coupon code has been PM'd to all those who had committed. If anyone has no received it please let me know. Link to comment https://www.sau.com.au/forums/topic/460654-alpha-omega-racing-evo-350mm-big-brake-kit-group-buy-round-2/#findComment-7638053 Share on other sites More sharing options...
Robzilla32 Posted November 13, 2015 Share Posted November 13, 2015 Won't be able to confirm by tonight, so I'm a no go. May have to wait for the next gb. Post pics when you've installed people First pic of the fronts (please ignore the missing front lip) Link to comment https://www.sau.com.au/forums/topic/460654-alpha-omega-racing-evo-350mm-big-brake-kit-group-buy-round-2/#findComment-7638060 Share on other sites More sharing options...
Robzilla32 Posted November 23, 2015 Share Posted November 23, 2015 Shot of the front left. Looking forward to the arrival of the rear kits. Link to comment https://www.sau.com.au/forums/topic/460654-alpha-omega-racing-evo-350mm-big-brake-kit-group-buy-round-2/#findComment-7642762 Share on other sites More sharing options...
