Stripping out my R33. Some parts will be priced some parts ill take decent offers on.
Headlights - Best offer
Tail lights - Best offer
Bonnet (s2 black) - Best offer
Reo bar - Best offer
Mirrors - Best offer
Rear seat - Best offer
Passanger seat - Best offer
Cluster - Best offer
Carbon boot with pins (flush style) clear has oxidizing - Best offer
Rear bar - Best offer
Front 1/4 panels - Best offer
Clutch master and slave cyl - Best offer
Washer bottle and pumps - Best offer
Catch can - Best offer
Over flow bottle - Best offer
Whole doors - Best offer
Stock turbo with manifold and lines - Best offer
Momo steering wheel (old school) with boss kit - Best offer
Surge tank with 044, proflow fittings and loom and proflow filter $350 ono
Tomei 500hp In tank pump $200 ono
Axles - $200 pair ono
Locked diff 4.3 ratio - $350 ono
Stock front bar with Nismo (style) JJR unpainted bar (brand new) $450 ono
R32 GTR intercooler $300 ono
Alloy rad 55mm with Greddy rad cap and Gates silicone hoses $280 ono
Rear camber arms - $180 ono
Rear traction arms - $180 ono
Rear sway bar (whiteline 43mm) $220 ono
I MAY HAVE MISSED SOME STUFF, JUST ASK AND ILL SEE WHAT I HAVE
Text or sms PHILL on 0421 986 981
BUMP PRICE DROP
320 for surge tank/044 pump setup
150 for axles pair
320 ono for diff
280 intercooler ono
250 alloy rad firm
400 front bar
Interesyed in flogging off the 12V cable and tray that runs under the car to the rear battery?
Throw over a pic of what you want.
http://www.nismo.co.jp/en/products/competition/lb/img/reinforcing/img_bnr34c.jpg
See the white platic next to the right chassis rail near brake lines and fuel lins. It has the power canle from your battery in the boot to front fuse box...i want the tray, cable complete with lugs on either end :)
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
