Stripping out my R33. Some parts will be priced some parts ill take decent offers on.
Headlights - Best offer
Tail lights - Best offer
Bonnet (s2 black) - Best offer
Reo bar - Best offer
Mirrors - Best offer
Rear seat - Best offer
Passanger seat - Best offer
Cluster - Best offer
Carbon boot with pins (flush style) clear has oxidizing - Best offer
Rear bar - Best offer
Front 1/4 panels - Best offer
Clutch master and slave cyl - Best offer
Washer bottle and pumps - Best offer
Catch can - Best offer
Over flow bottle - Best offer
Whole doors - Best offer
Stock turbo with manifold and lines - Best offer
Momo steering wheel (old school) with boss kit - Best offer
Surge tank with 044, proflow fittings and loom and proflow filter $350 ono
Tomei 500hp In tank pump $200 ono
Axles - $200 pair ono
Locked diff 4.3 ratio - $350 ono
Stock front bar with Nismo (style) JJR unpainted bar (brand new) $450 ono
R32 GTR intercooler $300 ono
Alloy rad 55mm with Greddy rad cap and Gates silicone hoses $280 ono
Rear camber arms - $180 ono
Rear traction arms - $180 ono
Rear sway bar (whiteline 43mm) $220 ono
I MAY HAVE MISSED SOME STUFF, JUST ASK AND ILL SEE WHAT I HAVE
Text or sms PHILL on 0421 986 981
BUMP PRICE DROP
320 for surge tank/044 pump setup
150 for axles pair
320 ono for diff
280 intercooler ono
250 alloy rad firm
400 front bar
Interesyed in flogging off the 12V cable and tray that runs under the car to the rear battery?
Throw over a pic of what you want.
http://www.nismo.co.jp/en/products/competition/lb/img/reinforcing/img_bnr34c.jpg
See the white platic next to the right chassis rail near brake lines and fuel lins. It has the power canle from your battery in the boot to front fuse box...i want the tray, cable complete with lugs on either end :)
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
