Gday guys. I have recently purchased a r32 gtst with a few things done to it. The person i bought it from was a bit unsure on the details of the mods as he bought it like it was.
Basic run down from what i can see is that it has a fmic and turbo back exhaust with a split dump. It has a dyno sheet for 211rwkw at 16psi. The car has no boost controller, the wastegate actuator is running straight from the intercooler piping.
My conceren is that i dont know what turbo is on the car. It has nissan on the compressor housing but it doenst have any numbers printed on it (like 16v or such) and there is also no flange for the intercooling pipe. It starts to spool up at around 3500 rpm and makes full boost by about 5500 rpm.
Im sorry but i don't have any pics to post up here just yet. It may be a bit difficult but does anyone have any ideas as to what turbo this may be?
Thanks guys
Ben
https://www.sau.com.au/forums/topic/460859-advice-on-what-turbo-i-have-please/
Im really sorry about the pic. Its the only one i have atm as the car is at the mechanics atm.
Apparently the vehicle has been running like this for at least the last three years. If this was the stock rb20 turbo would it be able to last three years on 16psi with out going pop?
Cheers
Ben
Would have to agree with the above. Nissan stamp but starts spool at 3.5, some sort of high flow core. Some turbo builders put a tag on their cores. See if u can spot one. A boost controller will def help bring the boost on earlier and harder.
That may explain the lag, the only thing that has me confused is the fact that there is no flange for the intercooler piping and there is no numbers stamped on the compressor housing.
Oh the joys of buying someone elses project haha
The compressor housing is definitely RB30ET. If the rest of the turbo was also originally a VL unit, then it's quite possibly no surprise that it doesn't perform really well.
What's really interesting is that while its behaviour sounds like a highflow job, the compressor inlet doesn't look like it's been machined out at all. Whatever the case, it probably doesn't belong on an RB.
To be honest it doesnt bother me too much that it is a bit laggy. Its my daily so driving around town not seeing boost is good for the fuel economy. I am mainly concerned about the exhaust wheel letting go if its a ceramic wheel thats all.
  • 3 months later...
The wastegate and bolt setup sounds like the turbo I had when I bought my Gts25t. I got it hiflowed and it made 245rwkw but was a teeny bit lightswitch - almost deadly on a wet day. I ended up going for a turbo with a better spread of power.
    • Yes the gear for the R33/34 is different, it is red and has a different number of teeth. My part didn't come with that gear though, so I don't know how many teeth are on the red one. You'd have to reuse the 260RS/R33 gear, as long as it's not destroyed.   Haha, as unfortunate as that might be it was working fine for about the first 1500km I've had the car for now.
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
