Gday guys. I have recently purchased a r32 gtst with a few things done to it. The person i bought it from was a bit unsure on the details of the mods as he bought it like it was.
Basic run down from what i can see is that it has a fmic and turbo back exhaust with a split dump. It has a dyno sheet for 211rwkw at 16psi. The car has no boost controller, the wastegate actuator is running straight from the intercooler piping.
My conceren is that i dont know what turbo is on the car. It has nissan on the compressor housing but it doenst have any numbers printed on it (like 16v or such) and there is also no flange for the intercooling pipe. It starts to spool up at around 3500 rpm and makes full boost by about 5500 rpm.
Im sorry but i don't have any pics to post up here just yet. It may be a bit difficult but does anyone have any ideas as to what turbo this may be?
Thanks guys
Ben
https://www.sau.com.au/forums/topic/460859-advice-on-what-turbo-i-have-please/
Im really sorry about the pic. Its the only one i have atm as the car is at the mechanics atm.
Apparently the vehicle has been running like this for at least the last three years. If this was the stock rb20 turbo would it be able to last three years on 16psi with out going pop?
Cheers
Ben
Would have to agree with the above. Nissan stamp but starts spool at 3.5, some sort of high flow core. Some turbo builders put a tag on their cores. See if u can spot one. A boost controller will def help bring the boost on earlier and harder.
That may explain the lag, the only thing that has me confused is the fact that there is no flange for the intercooler piping and there is no numbers stamped on the compressor housing.
Oh the joys of buying someone elses project haha
The compressor housing is definitely RB30ET. If the rest of the turbo was also originally a VL unit, then it's quite possibly no surprise that it doesn't perform really well.
What's really interesting is that while its behaviour sounds like a highflow job, the compressor inlet doesn't look like it's been machined out at all. Whatever the case, it probably doesn't belong on an RB.
To be honest it doesnt bother me too much that it is a bit laggy. Its my daily so driving around town not seeing boost is good for the fuel economy. I am mainly concerned about the exhaust wheel letting go if its a ceramic wheel thats all.
  • 3 months later...
The wastegate and bolt setup sounds like the turbo I had when I bought my Gts25t. I got it hiflowed and it made 245rwkw but was a teeny bit lightswitch - almost deadly on a wet day. I ended up going for a turbo with a better spread of power.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
