See, here's the thing: the two options I am researching are in the order of $400, not $800. And over $1000 is just silly.
Is that for just the oil cooler?
I use a Serck Marston and Earl remote locator sandwich/lines - all non Japanese. The parts are pretty cheap. Total cost was less than any Japanese unit..
Id go this avenue as well. You can get a 15 row cooler for about $180-200, or a 19 row Serck cooler for round th $250-300. Thats a good quality core that is used in motorsport and OE performance cars.
Then you can get the Earls sandwich plate for $50, the relocator flange is another $45 (going from memory so prices are approx)
Each Speedflow fitting will cost about $35 and 1 metre of braided line will set you back about $45. Hydraulic hose is cheaper at about $15-20 mtr
So assuming $300 for a 19 row cooler, with $50 sandwich plate, you will need 1.5mtrs of braided hose and 4 Speedflow fittings - Total = $550
OR including oil reolocator kit, add $50 for flange, another 2 Speedflow fitings and another 1mtr of braided line...So Total = $670
And something i thought of after i had bought all the bits for mine, is instead of getting an oil relocator flange for Nissan RB series, get one for something like a 351 Cleveland as the filter would be much bigger, and increase the volume of oil that little bit more :D
I dont believe you need to run a thermostat, some ppl do, but its another 4 Speedflow fittings and i cant see the value.
So its cheaper and arguably better to piece together your own setup, and the above prices are allowing for braided line so can be had cheaper if you run hydraulic hose and shop around for good prices on oil cooler.
So the only additional cost is a case of beer for the job, about $10 for 500mm of 25x3mm flat bar and some bolts and you can mount it yourself.
Roy- where would you mount this setup you're talking about??
I mounted the oil cooler behind the intercooler pipe on the drivers side. I cut out about an A4 sized piece from my inner guard and lined the cutout with some black aluminium mesh leftover from my front bar. In an R32 its a tight fit especially with crappy HKS cooler pipes that use up all the space...but it does fit.
I dont like the idea of mounting it after the intercooler and before the radiator, heat transfer thru IC then thru Oil Cooler then thru radiator, may not make a huge difference in the real world but on paper it seems to be a pretty big compromise.
Thought about the passenger guard as there is plenty of space over there, but i thought there could be issues with draining all the oil out of the lines come servicing, and braided line aint cheap enough to justify the additional $100 in runnng to a cooler located on that side of the car.
Roy- I'm pretty sure in this thread we are talking about 'oil coolers for GTR's', so in this case mounting the oil cooler on the driver side is a waste of time, since the blow off valves are located there, therefore the oil cooler must be placed on the passenger side inner fender, therefore costing more in braided lines....
Is it really that cramped up in there? I have seen several R32 GTRs with oil coolers in the drivers side guard.... so can be done in an R32, R33...who knows but on the GTSTs the R33 has more room again!?!?!?!
Im dribbling sh1t so dont listen to me :Oops: , but its still not a bad idea to buy the cooler you are after, then rip the bar off and see where the best place for it to go is, then be sure to buy the correct Speedflow fittings (90deg bends, 180deg bends etc) to squeeze it in there. still going to be cheaper then 80% of the jap kits...i say 80% because there are always ppl who need to get rid of gear and you need to be in the right place to pounce on a good buy :D
...ramble...ramble...ramble :Oops:
I feel I may have misrepresented myself - I'm not being cheap, and if it takes $1200 to get a good oil cooler then that's what I'll pay. My question really was: I can get a perma-cool (US made) oil cooler with a 21"x7"x1.5" core with oil relocation kit for $390AUD brand new, or a MOCAL kit with a 16row x 50mm x 235mm core for approx $500AUD brand new, but I have not seen any reports of how effective the perma-cool is. If the [insert jap brand] here is really 2-3x more effective than either of these options, then I'll pay 2-3x more. Roy seems to be in tune with my way of thinking - surely it's got to be cheaper and just as effective to build my own "kit" from assembled parts purchased independently. Have also had a look at sertrab cores - reviews?
Thanks for those who have offered suggestions - will take a harder look at earls and serck stuff...
This is what i got from earls australia at their online assistance.Keep in mind you can go bigger care sizes than the one i have been quoted for.
Hi Craig,
Thank you for your enquiry.
We do not carry oil cooler kits, all parts are individual.
Parts you will probably need Price including
GST
Cooler - 19 row 12" x 6" x 2"
$388.00
Sandwich adapter # 510 $58.00
Hose adapters # 981611 x 2 $23.00
Braided hose ends Straight $23.00
90 or 45 deg
$52.00
Braided hose # AN-10 $60.00
per metre
or plain rubber hose 5/8" ID
$31.00 per metre
Regards
Geoff
i put together a kit myself getting the parts from motorsport connections in seven hills - nsw
cost about $550 in parts, would have been cheaper if i didn't get the thermostat.
i used an oil cooler from a 7 series BMW, they are real big tube and fin alloy cores(as wide as my FMIC!
got it for $50 so im pretty happy, there is alot of fiddling to get it in there but it can happen...
that kit like jlnewton would be ideal if you can get a kit like that! really depends on what your gonna do with your car bambinator!
Hi Craig,
GST
 $388.00
90 or 45 deg
$52.00
per metre
$31.00 per metre
Regards
Geoff
I got my flanges from Earls in Silverwater as they were an ok price, but fittings, braided line etc i got from a place called Star Performance in Five dock NSW, try $130 cheaper for the same size cooler, $13 / mtr cheaper for the braided line and a few bob cheaper per fitting....and Motorsport Connections were also a little more expensive then Star Performance....
Shop around ppl and dont forget to also talk to old school V8 workshops who dont seem to operate on such high mark ups
I have to kick in for the DIYers guys. Shopping around can find you good stuff. For hoses and fittings I always check out the local Pirtek as they are usually pretty affordable.
You can also get oil coolers from RX7's and GT4 Celicas for just over $100 from many wreckers, and they come with a drain plug on the cooler for servicing. Thats a further reduction of cost. You don't need to have the brand name stuff.
I tend to just keep an eye on my oil condition during events. It isn't going to fail catastrophically and so as long as you monitor it there should be no reason for the cooler until you start doing massively long straights at full throttle for the whole time for multiple lap sessions of 10-15 laps or more eg Sandown with 2 long straights.
If your oil cooler is just for drags or show, well save your money.
I'd be interested to see if many of the guys "needing" oil coolers can give me a detailed reason for their fitment, supported by data on oil condition and temperature..........but if you can justify it, why spend more than you have to?
in my case, i used to do alot of track days, and with the front mount etc the cooling efficiency is greatly reduced through the radiator! the addition of the oil cooler not only maintains the effectiveness of the oil your using, it adds the total engine cooling!
i wouldn't think that you would need one if thats all you really do.... all about how far your gonna go with it! if you get into track days (which you will if you get out to one) it might come in handy.. just a prevention thing more than anything else!
Buy local is usually the cheapest way....does not have to mean lower quality....just make sure you get one with offset fin design..airflow is through the core at 45 degrees makes more area and more time for cooling.
addit:I think a thermostat is good if you use the car on the road as well. GTR properly set up for track with oil cooler big sump/baffles etc takes too long to warm up in normal driving
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
