For sale: Defi DIN gauges (discontinued)
2x temp in celcius, 1x pressure in kPa. LED backlight is green-ish.
Wiring plugs included, sensors not included.
Instruction manual found here: http://www.defi-shop.com/media/din-manual_1307-1_e.pdf
other bits and pieces for sale here: http://www.sau.com.au/forums/topic/459011-gtir-powerfc-z32-afms-sr20-gaskets-belts-earls-thermostat-various-pulsar-bits/
Condition: Good
Price: $400. SOLD
https://www.sau.com.au/forums/topic/460875-defi-din-gauges-sold/
Fit R32 triple gauge console space ?
Looks to but you can never be to sure.
im not sure. the DIN screw tabs on the sides can be removed easily with a phillips head.
can take measurements if requested.
fits 32 DIN no issues - have one in mine - good price.
apparently not. people been giving me shit over it, not including sensors.
am negotiable on price.
price drop to $400.
I managed to find all the sensors (coolant, oil pressure, oil temp) so ill throw those in for no extra cost.
Hey Leroy,
Still available? Post cost to NSW 2759?
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
