so i just got this tomei reg and im pretty sure its broke but want to make sure im not being a retard....
99% sure ive got the fittings in the right way. What happens is when you go to adjust the fuel pressure im taking off the vacuum line and blocking it so the reg thinks its at WOT and then winding the screw in (I'm pretty sure on almost every fps tightening raises the pressure up) but it seems to make the pressure go down then sometimes up then and it fluctuates then going the other way does the same thing and I cant get the pressure to get any where near 3kg/cm2 (43psi) only seems to sit at 2. Attaching the vacuum line doesn't effect the gauge at all and neither does blocking off the FPR vac line...when you rev the car the gauge goes down as well.
this sounds to me that the diaphragm inside has a tear in it letting more fuel through than its supposed to. Seeing as when I first started the car I could get 3kg/cm2 but wouldn't go any higher no matter where the screw was now I can only get two seems the longer it goes the bigger the tear is probably getting?
I'm sure its not the pumps as I have 040 feeding into 044 and can hear them both on and the car ran fine with stock fpr...
any ideas?
https://www.sau.com.au/forums/topic/461050-tomei-fpr-type-s-broken/
nothing really, but i wanted a gauge so i could check fuel pressure and I have two pretty strong pumps so wanted a larger diaphragm reg and apparently these rising rate ones offer better control over stock. Plus you can get dodgy and make your squirters go harder if you want to...
fuel leaking = fake Tomei FPR
get a Turbosmart FPR1200 or so, even Andy at Adaptronic did some tests and proved that these regulators control pressure very well.
Just my personal experience, I went from a Tomei Type-LJ regulator to a FPR1200 and my AFRs are now nice and smooth also my overall VE table has dropped allowing me to smooth out the values - I gathered the old regulator couldn't control fuel pressure properly.
its genuine, if its not then theve done a damn good job of copying it as it came with tomei stickers tomei instructions and a box covered in tomei shit and wasnt $40.
Either way this is the first tomei product ive bought and were not off to a good start, i just wanted to see if i was setting it correctly and it wasnt some other strange design than others ive used and it looks like its just broken.
thanks anyway!
  • Like 1
What about aeromotive regulators? with this I mean has there been decent testing in Australia by others regarding the quality of aeromotive regulators (A1000 Injected Bypass Regulator and Compact EFI Regulator) compared to the Turbosmart FPR1200??
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
