Hi all, what would it take to create a car for sound-off competitions?
I mean those crazy things that you see at car shows with heaps of speakers and subs and the like.
I've wanted to make one for a while, but other than the sounds gear, what else is needed?
I'm a little bit (Although not completely) clueless in this area, so any help would be useful.
Cheers
https://www.sau.com.au/forums/topic/461139-building-a-sound-off-car/
buy the right car first (panelvan, wagon, van, etc) then turn it into a giant sub enclosure. remove flex from all panels, seal everything up, with a shitload of expanding foam, sound deadener, bog and plywood...
then, fill it with the biggest subs possible, a crapload of high power amps with the right amount of power for the subs, good dozen of deep cycle batteries to provide the current, and don't forget all the zero gauge cabling
electrical is pretty much the same as any other audio setup, just at a bigger scale. you would at least need several batteries wired in parallel, some fat 0 gauge cabling between the batteries and the amps, upgraded alternator, properly rated fuses, a set of amps capable of driving all the speakers and subs you plan to install and maybe some capacitors as well.
i haven't done a setup like that myself, my most complex build was just a standard head unit/splits/pair of coax/two amps and a sub so wouldn't call myself an expert
Edited by junkie
Fair enough, what do you think the ballpark would be for all gear, excluding the car. Like 3-5k?
3-5k will build a decent oem replacement system with some good quality gear
but sound off, that's a whole different story. amps and subs cost a lot when pushing those kinds of power and decibel levels. plus, you would be up against some cars that have had six figures spent on the installs, so its a case of go hard or go home
I was only really thinking of it as a way to spend some time messing around, as an excuse to enter into shows and such. Not a completely nuts thing. Time to reconsider I think....
a wagon and not a coupe..
then a bunch of subs, slot ported individually and tuned using a SPL meter to see what resonate frequency the sub will peak at... each cabin is different.
I used to be into this shit 1.5 decades ago.
Fire it backwards to load it up (know as superpositioning) which will give you about a 3dB gain - approximately double the "loudness" and with careful port tuning you could pull another 2~3dB from the cabin gain.
I did 146dB with a single 12" Solobaric being fed 1.5kW back in the days however I had a 140L or so box.
I reckon a single 12" DD Subwoofer with about 1kW going to it will push you past 145dB easily in a ported box and if you feed it more it will make even more power.. downside is these subs don't go low and need huge boxes.
http://www.ddaudio.com/products/mobile-audio/woofers/dd9500
Question is, what is your goal and what is your budget?
You can go loud on a budget but you'll need at least a decent subwoofer/driver... get a pair of Jaycar monoblocks and strap them together
    • This is the territory of the "Stage 1/2/3 Golf GTI/R" or otherwise off the shelf tune with (relative to before) minor mods. It's easier now. Downpipe and Tune and boom, big increases. Stage 1 OEM+ is where it's at. This is where the niche evolved into and it's really easy to see why. It's rare to even NEED to consider changing turbos or going to aftermarket ECU's or building bottom ends for more power. Stage 1-2-3 will get you a LONG WAY. Civic Type R turbo GR Yaris/Corolla Anything with B58 (MKV Supra/x40i) Anything BMW in General Anything Audi in General Any turbo AMG RenaultSport Turbo offerings Korean Elantra N/I30N Ecoboost Mustangs Focus RS? List goes on. I would argue in the future it won't even need to go on... M3P is pretty rapid out of the box...
    • There is a way, but it's not with the same cars. You need to find the same vintage of car, that we had. Realistically, that was an affordable car with aftermarket parts around. So what people need to find is a car that had a decent base in its day, and can be modified. They're looking for a car year make of 2010 to 2015 really... Aus could have done it if Holden didn't fold as V8 commodores were cheap, and if Ford didn't get expensive thanks to COVID, then you could cheaply play with FG Barras. Realistically, those are just a bit heavier, four door skylines. I'm sure the US and UK have similar cars they could find.
    • Haha I do that.. thats when it chirps..The bit point for me is almost non-existent. Otherwise I stall it. But yes, in terms of performance, the clutch is solid af.
    • Greg speaks wisdom. These dirty old Datsuns are only value when they are cheap. When they are not cheap, there is no value. Sounds contradictory, but it's true. We are now 20 years past the hey day of modifying cheap 90s JDM cars for small amounts of money. This is a different world. If you are rich and can afford not to care about what is effectively wasting money on an old Datto shitter, then I have no reason to argue against it. But if you are wanting to experience what we all experienced back in 2005 (and I bought my car last century!) then there is no way to do it.
    • Short answer: No. Medium answer: No, because you still need to conjure the things out of thin air to bolt them to a NA to make it a NA+T. Long Answer: No - The things you need to conjure - meaning a turbo, intercooling, manifolds, exhaust, intake/manifold/piping, clutch, injectors, fuel pump, AFM (?), ECU + Wiring (woo, N/A loom fun) have to come from somewhere. You could have many scavenged these things from an OEM car that someone had upgraded from and use some of these. This will be cost prohibitive now, especially so in the USA. You'd probably pay the same for newer, upgraded components that are better than old OEM stuff from 25-30 years ago. None of these big ticket items are re-usable for the N/A car. Why not buy new and upgrade while you're there? The only real consideration is turbo and fuel sizing and determining whether you want to stay within the bounds of the OEM engine or get into rebuild territory. These limits ARE lower with a N/A motor and especially N/A gearbox at the starting point. And if you're gonna upgrade those then you may as well consider having them built to begin with. Because everyone here knows you're never far from that next engine rebuild once you start making the power you want... The cars you see on the internet and SAU etc have been built over decades. If you're really clued in... you would sell your US car to somebody for what you paid for it. You would then scour AU JDM pages or SAU and buy a car like Dose's on this forum with your powerful American Dollar. This will save you so much money in the long term. Importing it could be tricky. Or it might not because USA. I have long said the only reason 90's Japanese stuff took off was because a) Japanese people had Japanese cars so that is what they used b) Australians could import these cars to Australia with very minimal changes and use them on the road here c) Neither country had well-priced access to US or EU Sports Cars. I don't believe the JDM scene would have taken off in Australia at all if we had EU priced EU BMW M offerings, or more especially the AUS V8 Scene would never have existed if we had the multitude of US cars like Camaros, Mustangs, Corvettes at the prices you folks do. After all - Do the math. I would say put a V8 in your R34 and that's the smart way forward. It is. I did it. I know this from my own experience. But at that point there's no reason to simply not buy a C5 or C6? It would be simpler and easier and cheaper and bette-
