Thinking about getting rid of my dieselgate VW and picking up something a little more fun.
not looking to spend a fortune ($50-60k maybe a little more for the right car), and am thinking along the lines of;
2012 335i
2011 S4
2013/4 IS350 F sport
has anyone been down this track before and made a decision one way or the other?
https://www.sau.com.au/forums/topic/461163-335i-vs-s4-vs-is350/
Dang, some seriously nice cars there.
I think I'd be leaning toward the S4. Its by far the more 'performance' of the bunch and, being 4 door, more practical than the BMW at least.
What model Dieselgate is it?
I would probably go the F30 4 door if i ended up with the 335 anyway, trying to convince myself they are also practical. I am leaning towards the S4 as well though.
I have the Passat alltrack, looking at your cars there i would say we are in the same boat?
I'm not sure whether to cut my losses and trade it in or to hang on and see what happens with the class action - i bought early last year RRP $58k and i am looking at about $27k trade in at the moment..
  • Like 1
God damn thats painful!! I hurt for you. :(
dont go the audi. enough people around having issues or dealership woes or just maintenance in general.
Gotta agree here actually, Audi is just a VW in a diff skin anyway.
Test drove the Audi today - not as quick as i expected, still i think i will buy it tomorrow unless anyone really does know of any issues?
looks like they are easy to get some more power out of with a flash anyway:
https://www.revotechnik.com.au/datasheets/audi/revo-datasheet-audi-s4-b8.pdf
i have owned both Audis and BMWs forget about the 335i , get the E92 V8 M3 which has a bullet proof trans and engine .
Yeah there are a few floating around work, amazing cars - i just don't have the balls to turn up with a V8 given that they pay for my fuel and i drive a fair bit...
  • Like 1
Only interested in a sedan? Why not look at new golf R? would get it for 55-60, stage 1 tune and 283kw, 523nm 3.8 0-100 times. Then only uses 8L 100km too.
prefer sedan, i was looking at the new golf r wagon though - nice car but also not what I'm really after
The missus had an IS250 before, great car very reliable, a little under powered but if you get the IS350 should be fine. Never had a Audi so can't comment. Would stay away from BMW unless you really want it. We sold the IS250 and bought a BMW and the quality and reliability of BMW is not even close to the Lexus. The only upside with the BMW is the stock twin turbo v8 making over 400kw.
    • How much have you lowered?  I had 350Z springs in the rear and was able to pull the camber into factory spec with the factory arms on the rear, obviously the front ran negative camber as it isn't adjustable, but rotating the wheels regularly evened out the wear.
    • Either the installer needs to come back, you need an auto electrician, or you need to learn automotive electricals yourself.   First step Id look at is where that big thing came out of, is there still things unplugged at that location? Maybe they just forgot to put a relay in or something?
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
