Hi,
I recently got my R34 25GT Coupe and want to change the exhaust so I can make it louder but not too loud so it sounds off putting.
I'm a P Plater in Victoria, I hear I can only change the rear piping after the cat for it to be legal.
I'm not too sure what to look for exactly, been looking around for days with little luck, so can someone please point me in the right direction?
Thanks,
Jesse
https://www.sau.com.au/forums/topic/461200-na-r34-coupe/
Hi, and welcome to SAU, the best place in the world for all things Skyline.
According to the Victorian "P" Plate laws, any vehicle (Even Mum's Camry) can be considered prohibited if it: "has an engine that has been modified to increase the vehicle's performance (other than a modification made by the manufacturer in the course of the manufacture of the vehicle"
This means that exhaust mods are basically off the table for P Platers, as even a cat back, like you mentioned could theoretically give performance gains. Still, many do it anyway. (A cat-back on an N/A would give very small, even possibly non-existent gains)
If you still want to do this, try to be a bit stealthy about it. (An R34 with P Plates on it is already a cop magnet, regardless of modification level)
I personally suggest ringing up or emailing your local exhaust shop, and getting a quote for something made up and installed, as most popular brand made bolt on systems systems are for the GTT (Turbocharged) model.
Completely avoid the cannon, and try to stick to the stock twin tip look, to avoid attention from anyone unwanted.
Maybe look into getting an X-Force Varex muffler, which allows the volume to be controlled if you want to keep quiet if need be, to avoid unwanted attention.
The RB25 sound can actually be quite nice, if done properly.
Good luck with your R34.
Edited by Burger
https://www.sau.com.au/forums/topic/461200-na-r34-coupe/#findComment-7642192
Thanks Burger, I'll have a look.
To get a good sound, do you reckon I should look out for a muffler with a 2.5" inlet and a 3" outlet?
I found a single tip and double tip that look alright but not entirely sure what I should look for when referring to sizing.
https://www.sau.com.au/forums/topic/461200-na-r34-coupe/#findComment-7642214
Awesome. How much all up - $550? It's the first mod I did on my N/A back in the day. Very handy passing cops, going through RBT's, driving inlaws, being taxi boyfriend, talking, etc.
With mine, adding a pod makes a difference to the exhaust sound. better inhale = better exhale. or maybe a high flow filter will work on your airbox. I never tried it though.
Both is illegal here in NSW too. I got away with it for 3 years and I got defected for Pod filter. They said nothing about the exhaust. Now using the airbox since that day and my GF driving it now.
Just don't spend anything else until you get turbo skyline, you'll need the money, trust me! been there done that! :P
Goood luck
  • Like 1
https://www.sau.com.au/forums/topic/461200-na-r34-coupe/#findComment-7646885
Yeah it was around 700 really, paid a bit extra to get it done properly considering I went to a few places that said they couldn't do the job.
I'd love the turbo but I'm not sure if I'd be able to make the extra money for when I get off my p plates.
Would love a garage too, less likely to be keyed!
https://www.sau.com.au/forums/topic/461200-na-r34-coupe/#findComment-7646948
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
    • One way of putting the fuel surge idea to rest, is that even when in neutral/clutch in or free revving it still has the same issue, it can’t even get to limiter (7800) so to me that says it can’t be g force, I’m not trying to argue I just want to find the f&$king issue 😡
