Hi,
I recently got my R34 25GT Coupe and want to change the exhaust so I can make it louder but not too loud so it sounds off putting.
I'm a P Plater in Victoria, I hear I can only change the rear piping after the cat for it to be legal.
I'm not too sure what to look for exactly, been looking around for days with little luck, so can someone please point me in the right direction?
Thanks,
Jesse
https://www.sau.com.au/forums/topic/461200-na-r34-coupe/
Hi, and welcome to SAU, the best place in the world for all things Skyline.
According to the Victorian "P" Plate laws, any vehicle (Even Mum's Camry) can be considered prohibited if it: "has an engine that has been modified to increase the vehicle's performance (other than a modification made by the manufacturer in the course of the manufacture of the vehicle"
This means that exhaust mods are basically off the table for P Platers, as even a cat back, like you mentioned could theoretically give performance gains. Still, many do it anyway. (A cat-back on an N/A would give very small, even possibly non-existent gains)
If you still want to do this, try to be a bit stealthy about it. (An R34 with P Plates on it is already a cop magnet, regardless of modification level)
I personally suggest ringing up or emailing your local exhaust shop, and getting a quote for something made up and installed, as most popular brand made bolt on systems systems are for the GTT (Turbocharged) model.
Completely avoid the cannon, and try to stick to the stock twin tip look, to avoid attention from anyone unwanted.
Maybe look into getting an X-Force Varex muffler, which allows the volume to be controlled if you want to keep quiet if need be, to avoid unwanted attention.
The RB25 sound can actually be quite nice, if done properly.
Good luck with your R34.
Edited by Burger
https://www.sau.com.au/forums/topic/461200-na-r34-coupe/#findComment-7642192
Thanks Burger, I'll have a look.
To get a good sound, do you reckon I should look out for a muffler with a 2.5" inlet and a 3" outlet?
I found a single tip and double tip that look alright but not entirely sure what I should look for when referring to sizing.
https://www.sau.com.au/forums/topic/461200-na-r34-coupe/#findComment-7642214
Awesome. How much all up - $550? It's the first mod I did on my N/A back in the day. Very handy passing cops, going through RBT's, driving inlaws, being taxi boyfriend, talking, etc.
With mine, adding a pod makes a difference to the exhaust sound. better inhale = better exhale. or maybe a high flow filter will work on your airbox. I never tried it though.
Both is illegal here in NSW too. I got away with it for 3 years and I got defected for Pod filter. They said nothing about the exhaust. Now using the airbox since that day and my GF driving it now.
Just don't spend anything else until you get turbo skyline, you'll need the money, trust me! been there done that! :P
Goood luck
  • Like 1
https://www.sau.com.au/forums/topic/461200-na-r34-coupe/#findComment-7646885
Yeah it was around 700 really, paid a bit extra to get it done properly considering I went to a few places that said they couldn't do the job.
I'd love the turbo but I'm not sure if I'd be able to make the extra money for when I get off my p plates.
Would love a garage too, less likely to be keyed!
https://www.sau.com.au/forums/topic/461200-na-r34-coupe/#findComment-7646948
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
