Hey all,
Have just installed 6 X RX-7 550cc Injectors into my RB using the factory rail etc.. Injectors have been modified with an RB26 receiver so they plug straight up :) Have also just rebuilt injectors with speed-flow kits for peace of mind..
Anyways.. Does anyone know the exact resistance these injectors run from factory? Apparently its slightly different to an RB26 Injector..
Just wondering so I can go out and get the correct resistor..
Any further info on the resistor install would be great also :)
Cheers :)
https://www.sau.com.au/forums/topic/461210-13b-550cc-injectors-into-rb-help/
Or realise that "slightly different" to RB26 injector resistance can mean something like <1ohm (difference from RB26, not the actual resistance), whilst the target you're trying to reach is something like 12-14 ohms and the ECU won't be that fussy about what the actual resistance you show it ends up being.
Wow Ive been given some shit for this one haha.. Didnt have a Multimeter about this morn and was being a semi lazy bastard haha, I say semi lazy because I did have a search but the Same part number applies for both high and low impedance 13b Jecs.. Only difference was the connector colour which ofcourse has been changed.. p.s 2001 was a great year.
  • Like 1
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
