Android Headunits
PranK
 Share
Hi All,
I'm picking up my new daily tonight. The Bora died and I'm getting a few-year-old Mazda 3.
I'm thinking of ditching the integrated stereo and installing an Android double din. I can have Bluetooth and maybe even a reverse camera which I'd like.
My question is, if I park the car and go into a shop, when I come back and turn on the car again, will it resume from where I left off? I don't want to have to start the music/radio manually every time I start the car.
Has anybody installed one of these? I'd love some feedback.
Thanks,
Christian
I considered an android head unit, but seeing as they are all basically no name China stuff ended up with a kenwood unit.
Streams Bluetooth of course, mirrors phone display, can control phone from touch screen with cable, uses Pandora, heaps of inputs, reverse camera etc.
Yah, this is kinda how i'm leaning.
Do you know model number? Or approx cost?
Those Kenwood units are poo , Depending on what phone you have Iphone or Andriod ,will determine the Head Unit that will work best ,Plus how much nav you use ,etc etc ,
Most will resume ,Pioneer are the top of the tree followed by Alpine ,depending on your phone !!Everyone else is playing catch up .
Most good audio stores ,Autobarn ,some JB will have demos you can plug into and test.
Maybe calling the Kenwood Poo is a bit harsh ,It reminded of a chinese turbo or an AK47,.The Kenwood headunit 5015 i demoed was temperamental,voice control was hit and miss ,bluetooth took 4 goes to hook up ,the audio guy said Kenwood had a lot of issues with there smart phone compatible units and about a 30% return rate .The Pioneer worked faultlessy with an Andriod phone but was slow with an I Phone ,by the time we got to the Alpine i had a headache from talking to a machine .I think it is like anything you get what you pay for :D plus the operating system on your phone has a bit to do with it as well
 Share
    • This morning I carefully reinstalled the manifold and started looking at a couple of things I need to do.  Heat wrap arrived sometime today so I popped into the shed with the missus dishwashing gloves and started wrapping the first half of the dump and the screamer/plumb back.  Once I do the second half I'll be able to final fit the turbo and exhaust up.  Also pulled the harness out today and started terminating it at the ECU end. A connector is done, just need to run the remaining wires that arent in the harness - 12v, gnd and couple I/O
    • A31 is pretty much the same thing without HiAIDS I mean CAS, no improvement lol. Not to late to send it.
    • Thanks for all the replies! I also wanted to ask if wheels that were fitted on Ford Falcons would fit the 350GTs as well? In the area I'm at there aren't that many options for secondhand wheels and new ones here are way out of my budget. From what I've seen, most of the wheels that are available that were fitted on Ford Falcons have an offset of +33 to +36, with a centre bore of 70.5mm whereas the stock 350GT's ones are 66mm, can't seem to find any hubcentric rings that fit that difference though.
    • 215/45/18 tyres are probably a little on the low side compared to the factory tyre, it should be closer to a 245/45/19, which will get you about an extra 11mm of height, and should make you speedo read a bit closer to reality. 245/45/19s will be a bit too far the other way and you risk a speeding ticket as your speedo might read slower than your actual speed.  245/40/19s would be correct if you are going to 19in rims, they will give you a similar total diameter to the 245/45/18 tyres.
    • That's something I forgot to put in my list. The aggressive anti-squat in R32 is a f**king menace. I still need to decide if I'm going to drag the subframe out of my car and weld in the GKTech corrector kit. The main reason to dither is the need to switch to spherical joints in the lower arm to account for the twist induced in the rear pivot caused by lowering the front pivot. And yes...we do put better subframes in R32s, and I wish I'd gotten an S14 one instead of an A31 when I did the "take off and nuke it from orbit" HICAS delete all those years ago.
